good side up or down?
Forum topic by daddywoofdawg posted 09-01-2015 08:19 PM 1086 views 0 times favorited 7 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1602 days
09-01-2015 08:19 PM
I’m cutting some A/C ply with a circular saw,and can’t remember good side up or down?
7 replies so far
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#1 posted 09-01-2015 08:31 PM
Good side down for circular saw. Good side up for tablesaw.
View FellingStudio's profile
FellingStudio
93 posts in 1710 days
#2 posted 09-01-2015 10:27 PM
Think about it like this … on which side will the veneer be supported when the sawblade’s teeth hit it? The teeth should always go into the good/show side because that veneer is fully supported by the substrate. When the teeth exit the cut on the opposite side they have a tendency to pull the veneer away from the substrate causing tearout.
-- Jesse Felling - http://www.fellingstudio.com
daddywoofdawg
#3 posted 09-01-2015 10:49 PM
then you’re saying good side up? with a skilsaw/circular saw?
View SuperCubber's profile
SuperCubber
1027 posts in 2312 days
#4 posted 09-01-2015 10:59 PM
The side in which the saw blade’s teeth exit the wood at the front of the cut should be the bad side. With a circular saw, the blade exits the top, so you want good side down. With a table saw, the blade exits the bottom side of the wood, so good side up.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View rwe2156's profile
rwe2156
2967 posts in 1508 days
#5 posted 09-02-2015 02:05 PM
Good side down!
View HokieKen's profile
HokieKen
5274 posts in 1166 days
#6 posted 09-02-2015 07:36 PM
Definitely good side down. Blade teeth should always go into the good side and come out the bad side.
-- Kenny, SW VA, Go Hokies!!!
View bonesbr549's profile
bonesbr549
1558 posts in 3094 days
#7 posted 09-02-2015 08:06 PM
- HokieKen
+1 go HOKIES!!!!!!!!!!!!!!!!!!
