How Big To Make Turning Blanks
Forum topic by alaskan79 posted 11-11-2009 07:35 AM 1105 views 0 times favorited 2 replies Add to Favorites Watch
View alaskan79's profile
74 posts in 3289 days
11-11-2009 07:35 AM
I have some nice Cherry logs that I am going to be milling and I was wondering how big do you make turning blanks. Example do you make them 6” X 6” X 6”, or 4” thick and 6” X 6”. Also do you just Anchorseal the ends or edges or the whole thing?
-- alaskan79, Michigan
2 replies so far
View lew's profile
11989 posts in 3691 days
#1 posted 11-11-2009 05:01 PM
I have found that even though my lathe can handle something physically 14” in diameter, a blank that size is tool large for the power of the lathe. This is especially true for a large bowl blank.
That said, the size of the blank is also determined by the project and the characteristics/character of the wood itself.
As for the sealer, I think most people just put it on the end grain. However, some of the blanks I have purchased from Woodcraft have a waxy coating over the entire piece.
View tamboti's profile
207 posts in 3077 days
#2 posted 11-11-2009 05:31 PM
Hi Henry The size of the blank depends on what u intend making and also the diameter of the log
If log 300mm 1 ft dia and u going to make a bowl cut log 350mm 1ft2’’ and split down pith and seal alround with a wax emulsion or pva paint also work or anchorseal so long as the product is not harmfull If u are going to make a hollow form i would just seaal the log after cut to size.
If making boxes with lids mill 6’’ X 6’’ X 6’’ this allows u room for design
All the above depends on what your lath can handle. For hollow form always remember to leave wood for chucking. U can also cut the bowl blanks round if u like butseal all round In Pretoria I check the seal +- every 3mths a lot depends on the climate were u are, Winter here 0- 19 c Summer 16- 35c.
Good luck and feel free to pm me Regards Roger SA
-- Africa is not for sissies
