Sanding after stain?
Forum topic by Nuke33 posted 11-10-2009 10:20 PM 1168 views 0 times favorited 3 replies Add to Favorites Watch
View Nuke33's profile
Nuke33
3 posts in 3051 days
11-10-2009 10:20 PM
I just put a coat of stain (Oil Based) on a project. Should I give it a light sanding before apply waterlox?
Thanks,
Ryan
3 replies so far
27251 posts in 3723 days
#1 posted 11-10-2009 11:56 PM
Ryan, you do not need to sand. You might want to add a seal coat of shellac to prevent the stain from bleeding into the topcoat but I have successfully used oil base stains under a tung oil finish without sealing.
View huff's profile
huff
2828 posts in 3187 days
#2 posted 11-11-2009 12:03 AM
Would not recommend sanding….....you stand a good chance of changing the color density in areas. Put a sealer coat on next, then lightly sand. Good luck.
-- John @ http://www.thehuffordfurnituregroup.com
View bruc101's profile
bruc101
1197 posts in 3443 days
#3 posted 11-11-2009 01:39 AM
If you like using Waterlox, try mixing your stain in the Waterloc and apllying them together
-- Bruce Free Plans http://plans.sawmillvalley.org
