Dust Collection Pipe
Forum topic by jayvansickle posted 08-30-2015 11:05 PM 1938 views 1 time favorited 14 replies Add to Favorites Watch
View jayvansickle's profile
jayvansickle
25 posts in 1313 days
08-30-2015 11:05 PM
I am getting everything ready to run a dust collection system in my 24’ X 24’ shop. I am looking for 4” clear dust collection pipe. Everything I have found is outrageously expensive. I only want a 3-4 foot long piece. Does anybody know where I can find clear pvc or plexiglass, etc.? Any help would be appreciated.
-- If a parsley farmer goes broke, can they garnish his wages
14 replies so far
View Andre's profile
Andre
2362 posts in 2044 days
#1 posted 08-30-2015 11:37 PM
I used thin wall white PVC from H.D. with strategically placed unglued joints in case of pluggage, none so far!
View CharlesA's profile
CharlesA
3358 posts in 2035 days
#2 posted 08-30-2015 11:41 PM
That stuff is expensive. Here is a piece for about $60 shipped.
That’s a good argument for clear flex tubing.
View joey502's profile
joey502
544 posts in 1756 days
#3 posted 08-31-2015 11:28 AM
I am curious, why do you want the pipe to be clear?
jayvansickle
#4 posted 08-31-2015 01:36 PM
I want to be able to verify that the dust collection is not plugged up.
CharlesA
#5 posted 08-31-2015 01:38 PM
I cut a 4×6 square out of my 55 gal drum and put a piece of plexiglass over it so I can see what’s entering and check to see how full it is. This would only work with a separator, of course.
jayvansickle
#6 posted 08-31-2015 01:43 PM
Good idea. I am going to use a separator. Thanks.
View buildingmonkey's profile
buildingmonkey
242 posts in 1785 days
#7 posted 09-03-2015 05:07 PM
Most guys use the S&D 2729 thin wall plastic for plastic dust piping. The fittings are low cost as is the pipe. Check your local lumber yard. Or plumbing supply.
-- Jim from Kansas
View splintergroup's profile
splintergroup
2505 posts in 1460 days
#8 posted 09-03-2015 05:46 PM
As stated, pricey!
$45 plus $5 for shipping will get you 3 feet on Amazon (or $16/ft)
How about flexible hose A lot cheaper (10 ft, $35 free ship).
Both options won’t stay clear for long as the dust will stick and ‘fog’ the plastic anyway.
View RobS888's profile (online now)
RobS888
2523 posts in 2083 days
#9 posted 09-03-2015 06:55 PM
- buildingmonkey
+1!
Also, Rockler blast gates have a tight fit in 2729 and their clear hose just fits on the end, so you just need a clamp, no adaptor.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
jayvansickle
#10 posted 09-05-2015 04:58 AM
- buildingmonkey
I have already bought the s & d pipe. Saved a bunch of money versus regular PVC. The cost of 4” flexible dust pipe is outrageous. Know wonder everybody is using PVC.
jayvansickle
#11 posted 09-06-2015 07:49 PM
I took the plunge yesterday and bought a Harbor Freight dust collector. Assembly went well (once I stopped using the directions) maybe a an hour to finish. I had exactly the right number of nuts, bolts, and washers. Actually, I had 20-25 extra washers when done. I was doing some test fits with PVC and adapters to 4” dust pipe. I spent 20 minutes scraping off a sticker. Why do companies put those big stickers on that don’t just peel off? Pain in the butt!
Last night I came across a YouTube video “On the cheap dust collector. Thein baffle”. In the video he has figured a way to fabricate a fitting to go between PVC and dust pipe that is really slick using PVC. Check it out.
View Marv88's profile
Marv88
87 posts in 2137 days
#12 posted 09-26-2015 04:13 AM
I bought some of my dust collection parts from Busy Bee Tools and ran across 3 ft of clear 4” tube for $15.99.
http://www.busybeetools.com/products/clear-tube-4in-x-3ft.html
Shipping was from Canada but it was only $25.00 to California for 10 ft of 5” hose and several 5” fittings/clamps so I would imagine it would be quite a bit less for just one plastic pipe depending on where you are
-- "Post count on a forum does not denote level of knowldege, skill nor experience"
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#13 posted 09-26-2015 10:27 AM
Before you get too far with your project it is generally considered 4” pipe will seriously degrade the performance of your collector. I think you’ll find 6” is the standard recommended for any collector over 800CFM.
Aside from that, you’re never going to clog the pipe so don’t worry about it.
View GT350's profile
GT350
370 posts in 2219 days
#14 posted 09-26-2015 03:46 PM
- jayvansickle
I used 4” white PVC on mine and I have only had it plug up a few times. You don’t have to see if it is plugged up it will just stop flowing and you will know. The only times I have ever had it plug up was when I was planing some softwood like cedar.
Mike
