Drawing a large radius
Forum topic by daddywoofdawg posted 08-30-2015 03:59 PM 871 views 0 times favorited 7 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1813 days
08-30-2015 03:59 PM
I have a design that requires some large radius ( 60.2”,60.45”,58.2”,57.95”radius) on narrow boards (X4,X6).How do I make radii that large? A big beam compass,A bent board (how do I figure the radii with that?) or is there a better way?
7 replies so far
View waho6o9's profile
waho6o9
8539 posts in 2815 days
#1 posted 08-30-2015 04:09 PM
A 4×8 sheet of plywood and a folding ruler come to mind.
Lay it out and set your trammel points / beam compass and your golden.
View Redoak49's profile
Redoak49
3740 posts in 2226 days
#2 posted 08-30-2015 04:12 PM
I would use a long board with a nail thru it for center and drill a hole that is a snug fit for a pencil. Getting that large a circle to the hundredths of an inch may be extremely difficult.
View BurlyBob's profile
BurlyBob
6031 posts in 2503 days
#3 posted 08-30-2015 07:20 PM
I’ve done it exactly like Redoak says and I have to agree those are pretty exacting dimensions.
View Ghidrah's profile
Ghidrah
667 posts in 1460 days
#4 posted 08-30-2015 08:23 PM
I’d use a nail and 10 or 12’ tape measure, don’t waste the wood. I’ve used this method on arched doorways, breezeways and garages tons.
-- I meant to do that!
View JeffP's profile
JeffP
573 posts in 1630 days
#5 posted 08-30-2015 09:59 PM
Or just a nail and a carefully measured piece of thin wire with a pencil at the other end.
If you’re not doing a whole mess of them, I would just go with something really simple like a small nail taped in the “crook” at the end of a tape measure as your center point, then pull the tape out to desired radius and lock it…then lay a pencil in the corner between the tape and the tape-measure housing and hold it there while you scribe your line.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View Kazooman's profile
Kazooman
1268 posts in 2190 days
#6 posted 08-30-2015 10:07 PM
OK, curious minds want to know. What on earth are your up to? Arcs with 1/4” difference over a 60” radius!
I can only imagine that you are making something with a 1/4” curving band in it. If that is the case, note that you do not want to change the radius by 1/4”. You want a constant radius and need to move the center point 1/4”. You probably couldn’t see the difference by eye, but there is a difference.
So, what is the project???
daddywoofdawg
#7 posted 08-31-2015 07:31 AM
It’s like 2” width on the curves,I just put them in size order.one has a 60.45 and the 57.95 inside radii.
I’m thinking I can draw it on some Masonite,cut it out and make a template.
