Anyone have the Delta "disappearing splitter"?
Forum topic by ForestGrl posted 08-30-2015 04:30 AM 3570 views 0 times favorited 11 replies Add to Favorites Watch
View ForestGrl's profile
ForestGrl
450 posts in 1056 days
08-30-2015 04:30 AM
Topic tags/keywords: unisaw splitter delta splitter disappearing splitter tablesaw question
I’m looking at the Delta “disappearing splitter” to go along with an overhead blade guard on my Unisaw. I can’t seem to find much information on how it works, how hard/easy it is to install, how well it works. Anyone out there with first-hand experience?
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
11 replies so far
View bruc101's profile
bruc101
1200 posts in 3511 days
#1 posted 08-30-2015 05:00 AM
Amazon has some reviews on it. Maybe a jock will step in and give you some advice on one.
http://www.amazon.com/DELTA-34-868-Bracket-Splitter-Assembly/dp/B0007SXGQ0
-- Bruce Free Plans http://plans.sawmillvalley.org
MrUnix
6612 posts in 2168 days
#2 posted 08-30-2015 05:08 AM
I’ve got one on my saw… easy to operate with just a push/pull of a finger – no tools needed. It installs on the back trunnion with a couple of bolts. There is a spring loaded ball that engages with a detent on the splitter to keep it in the up position. The stock throat plates have a slot for the splitter to stick up through… aftermarket or homemade throat plates may need to be modified. I looked, but I don’t have any good pictures to show you unfortunately.
PS: They came stock with the Uni-guard AFAIK.
View CharleyL's profile
CharleyL
222 posts in 3334 days
#3 posted 08-30-2015 10:15 AM
I also have, and use, one. I bought it from someone in my woodworking club about 10 years ago when he bought a Shark Guard. They don’t work well with some blade guards, but my blade guard is a Brett Guard that hangs from the ceiling, so the guard and the pop-up splitter play well together. You can’t use it when using Grrippers and straddling the blade with them either, because the pop-up splitter has anti kickback pawls that stick up well above the blade height.
Whenever I want to use the pop-up splitter I just remove the throat plate, lift the splitter into position, and replace the throat plate. It pops back out of the way just as easy by reversing the process. The pop-up splitters seem to no longer be available, except used through Ebay or Craigs List. Keep watching there if you want one. Make sure they provide the little spring and detent ball when you buy a used pop-up splitter, because they can fall out easily when removing the splitter from the saw. These splitters will fit any of the 50’s through 90’s Unisaws and maybe even some made before that, but they won’t fit the newer Unisaw design that was made to use with a riving knife. Only 2 bolts are needed to attach them to the trunion – look for the machined flat vertical surface on the trunion just behind the saw blade and below the throat plate where the Delta splitter/blade guard attaches. You won’t be able to use one of these blade guard/splitter combinations if you want to use the pop-up splitter. They both mount in the same position. You will need to add a slot to your home made throat plates, but the original factory made throat plates all have this slot.
ForestGrl
#4 posted 08-30-2015 06:59 PM
I also have, and use, one. I bought it from someone in my woodworking club about 10 years ago when he bought a Shark Guard. They don t work well with some blade guards, but my blade guard is a Brett Guard that hangs from the ceiling, so the guard and the pop-up splitter play well together. You can t use it when using Grrippers and straddling the blade with them either, because the pop-up splitter has anti kickback pawls that stick up well above the blade height.
Whenever I want to use the pop-up splitter I just remove the throat plate, lift the splitter into position, and replace the throat plate. It pops back out of the way just as easy by reversing the process. The pop-up splitters seem to no longer be available, except used through Ebay or Craigs List. Keep watching there if you want one. Make sure they provide the little spring and detent ball when you buy a used pop-up splitter, because they can fall out easily when removing the splitter from the saw. These splitters will fit any of the 50 s through 90 s Unisaws and maybe even some made before that, but they won t fit the newer Unisaw design that was made to use with a riving knife. Only 2 bolts are needed to attach them to the trunion – look for the machined flat vertical surface on the trunion just behind the saw blade and below the throat plate where the Delta splitter/blade guard attaches. You won t be able to use one of these blade guard/splitter combinations if you want to use the pop-up splitter. They both mount in the same position. You will need to add a slot to your home made throat plates, but the original factory made throat plates all have this slot.
- CharleyL
Thanks, Charley. I’m a little confused though. Is yours the same splitter as this one at Amazon ?? So far, it sounds pretty good. My Unisaw is probably a 90’s model, I bought it from a cabinet maker who had to move out of state to care for aging parents about 6 years ago, it was well-used but not old. Should look up the serial number I guess. ;-) Will be using my PSI overhead guard, mounted from the ceiling, should be fine.
ForestGrl
#5 posted 08-30-2015 07:05 PM
I ve got one on my saw… easy to operate with just a push/pull of a finger – no tools needed. It installs on the back trunnion with a couple of bolts. There is a spring loaded ball that engages with a detent on the splitter to keep it in the up position. The stock throat plates have a slot for the splitter to stick up through… aftermarket or homemade throat plates may need to be modified. I looked, but I don t have any good pictures to show you unfortunately.
- MrUnix
Thanks for the review, Brad, it sounds perfect to go with the PSI overhead guard that I already have. The PSI originally mounted on a Jet contractor saw paired with a Merlin splitter, but when I got the Unisaw and sold the Jet, I never put together a guard/splitter team for the Unisaw. Now that I’m back in the shop, time to do that, ‘cause I really hate the stock guard, but won’t work without something there.
MrUnix
#6 posted 08-30-2015 07:10 PM
Looks exactly the same to me… I don’t think they changed the design any over the years. Here is a picture showing it mounted to the rear trunnion (not the best picture, but should give you an idea):
And this is a shot of what the spring loaded ball and set screw looks like removed from the splitter:
If you look at the first picture, you can see the hole in the splitter mount where the spring, ball and set screw installs.
PS: If you have the serial number, you can date your saw here:
http://wiki.vintagemachinery.org/DeltaSerialNumbers.ashx
ForestGrl
#7 posted 08-31-2015 04:15 AM
[Snip] The pop-up splitters seem to no longer be available, except used through Ebay or Craigs List. Keep watching there if you want one. Make sure they provide the little spring and detent ball when you buy a used pop-up splitter, because they can fall out easily when removing the splitter from the saw.[Snip]- CharleyL
This is the part that confuses me. Sounds like there is an old “pop-up splitter” and this new(er) “disappearing splitter.” If I do look on eBay, I need to be sure what’s what. ;-)
ForestGrl
#8 posted 08-31-2015 04:24 AM
Looks exactly the same to me… I don t think they changed the design any over the years. Here is a picture showing it mounted to the rear trunnion (not the best picture, but should give you an idea):
[Snip]
- MrUnix
Wow, thanks for the pictures, Brad, appreciate it. I can see where the spring and detent ball would be very easy to lose. This puppy’s going on my Christmas list (or perhaps Labor Day, LOL).
CharleyL
#9 posted 08-31-2015 03:03 PM
The one on Amazon and the one in the pictures look to be the same as mine. The Amazon photo is a bit deceiving since it’s showing the bottom end rather than the top business end, but Brad’s pictures show it exactly. The new Delta company must be making them again, but $89 is a bit high to me for how simple the design is. But they are the only source if you want a new one.
Charley
MrUnix
#10 posted 08-31-2015 04:34 PM
I don’t believe Delta ever called it a pop-up splitter, although I have heard it called that for fairly obvious reasons. Here is the listing from a 1979 Unisaw manual about the Uniguard which calls it the disappearing splitter, so it’s by no means a new term :)
ForestGrl
#11 posted 09-01-2015 02:35 AM
Holy Smokes, I had no idea they made them in the early ‘90’s, let alone back when that ad was published (it might even be older than I am, LOL). The sellers on eBay must not realize they’re for sale new at $89/free shipping, ‘cause they want a ton for them. One seller is less than half retail, and I’ve sent him/her a question as to whether the spring and detent ball are included. There are no bolts, but seem they’d be easy to get, yes???
