Biscuits to align a workbench top during glue up?
Forum topic by skogie1 posted 08-30-2015 12:37 AM 950 views 0 times favorited 9 replies Add to Favorites Watch
View skogie1's profile
skogie1
105 posts in 1267 days
08-30-2015 12:37 AM
I’ve got a 7’, 4.25” thick, beech benchtop to glue up. It’s 2’ wide and in 2” strips so there are 12 planks to glue together. I plan on doing it in stages. I’m thinking of using some biscuits to help align but I’m not sure if that’s a good idea or not. Anyone have any thoughts on this? Pros and cons? Thanks in advance.
9 replies so far
View TheFridge's profile
TheFridge
8862 posts in 1390 days
#1 posted 08-30-2015 12:47 AM
Don’t see why not. At worst, you might have a small void on the inside of a couple of your dogholes that you never see unless you look for it.
View canadianchips's profile
canadianchips
2600 posts in 2901 days
#2 posted 08-30-2015 01:02 AM
I use biscuits for my harvest table tops. It made glue and clamping a lot easier.
View rwe2156's profile
rwe2156
2796 posts in 1384 days
#3 posted 08-30-2015 01:12 AM
You should be able to keep things lined up pretty good with boards that thick.
Its really an unnecessary extra step you’re gonna have to level the top anyway, right?
View cabmaker's profile
cabmaker
1694 posts in 2713 days
#4 posted 08-30-2015 01:51 AM
I use em every chance I GET !
View Pezking7p's profile
Pezking7p
3217 posts in 1555 days
#5 posted 08-30-2015 01:55 AM
Use the biscuits but plan around any dog holes or vises or plane stops, etc. the biscuits will save you a lot of planing later on.
Also, it’s rarely mentioned but make sure your jointed edges are square before glue up. Sounds obvious but it’s worth mentioning.
-- -Dan
skogie1
#6 posted 08-30-2015 02:39 AM
Thanks gentlemen. I’m attempting to minimize the amount of planing that I will need to do. The plan is to glue three boards together at a time, giving me 4 sections. Then run each of the four glue ups through the thickness planer. Then I’ll glue the 4 pieces together into two separate sections. Then I’ll run them through the thickness planer. Finally I’ll glue the two halves together creating the benchtop. At this point I’ll need to hand plane as it will not fit through the planer. I’m hoping that by doing it this way I can really reduce the amount of hand planing that I’ll need to do. Sounds like there’s no unseen drawbacks to using biscuits so I’ll go ahead as planned (other than positioning to avoid dog holes). Thanks again.
skogie1
#7 posted 08-30-2015 02:41 AM
And Pezking, yes, I spent nearly four hours getting my freaking jointer as true as possible before doing this job. Ever use the Oneway Multi Gauge? Once I got my hands on that it was a snap. Great little tool.
4873 posts in 2397 days
#8 posted 08-30-2015 01:19 PM
I just built a new bench top a few months ago. Not quite as thick (mine is 3”) but it is 7’ long. This was all 6/4 hard maple, glued on the wide face. Every joint has biscuits in it.
Smitty_Cabinetshop
15095 posts in 2522 days
#9 posted 08-30-2015 01:21 PM
Definitely ‘yes’ on biscuits. No reason not to.
