I can't a get a face on an irregular object in Sketchup
Forum topic by CharlesA posted 08-29-2015 07:19 PM 1029 views 0 times favorited 6 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3351 posts in 1999 days
08-29-2015 07:19 PM
Topic tags/keywords: question sketchup
The pic shows a shape I’ve drawn. I’m trying to make a bowl using follow me, but I can’t get it recognize as a completed shape and have a face. I can make it a group or a component, but only as a collection of lines instead of a two dimensional object. Any tips?
View JayT's profile
JayT
5961 posts in 2413 days
#1 posted 08-29-2015 08:21 PM
Probably means it’s not closed off somewhere. I’ve had instances where there is a single pixel gap in the lines and it prevents forming a face.
If you want to send me the file, I’ll look at it and see if I can find something you are missing. PM if interested and I’ll get you my email address.
View Daruc's profile
Daruc
460 posts in 1334 days
#2 posted 08-29-2015 08:24 PM
Looks like there is a problem with your curve drawing. Draw the top layer then use the offset tool for the bottom.
View lateralus819's profile
lateralus819
2241 posts in 2091 days
#3 posted 08-29-2015 09:43 PM
What I do for circular obects is this.
Draw the diameter of bowl you want. Then take half and draw a line vertical from the middle. Then make half the shape connect to the outside. it should make a half segment. Then I Follow me around the perimiter.
View BobLang's profile
BobLang
160 posts in 3602 days
#4 posted 08-29-2015 11:16 PM
My best guess is that some of the curves you have drawn are not in the same plane. Try drawing a rectangle first, the put the curves on the rectangle and erase the extra lines when you’re done. Look for tips saying “on face” as you draw the arcs. Also, you only need half a section as shown by lateralus819 above, to make a bowl.
-- Bob Lang, https://readwatchdo.com
CharlesA
#5 posted 08-30-2015 12:53 PM
Thanks everyone. I use sketchup a fair amount, but every once in a while I get stuck. BTW, Bob, I’ve found your sketchup videos incredibly helpful. I tried one set from someone else and I just couldn’t get it. But your approach helped (clearly, it didn’t help that much, but thanks).
BobLang
#6 posted 08-30-2015 09:22 PM
Glad that it worked
