Looking for tips applying brush on lacquer
Forum topic by bill1352 posted 11-09-2009 10:33 PM 17810 views 0 times favorited 4 replies Add to Favorites Watch
View bill1352's profile
bill1352
130 posts in 3027 days
11-09-2009 10:33 PM
Topic tags/keywords: finishing
I have no place to spray lacquer as it should be done so I tryed to brush it on with Miniwax & Deft products made for brushing. legs & aprons went fine, the top ended up stripped twice after about 6 or 7 coats each time. I tryed expensive brushes & made for oil foam brushes. I cant get rid of the brush marks. I ended up just using a pour on epoxy. maybe i just need to find somebody that can use a paint brush correctly…lol. I want something stronger then polyurethane for the table tops i make.
-- Keep Your Stick On The Ice
View MedicKen's profile
MedicKen
1610 posts in 3368 days
#1 posted 11-09-2009 10:44 PM
I use DEFT almost exclusively. It is wonderful and should be and has been very easy to apply. The thing I have found with it apply it heavy. Deft has a self leveling ability and will smooth out by itself. If you try to put on thin coats it will look spotty and streak. I use a good quality 2 1/2 sash brush with man made bristles. DO NOT thin Deft, use it right from the can after stiring it and try not to introduce air into the mix. Stir slowly. After letting each coat dry wipe with 0000 steel wool, remove the dust and apply another coat. I will apply 3 coats for general use and up to 6 if I want a water resistant surface.
bill1352
#2 posted 11-10-2009 01:39 AM
Thanks. Maybe I was going too thin as the can said to do. why i picked this product to follow directions with i’ll never know. sure cost me time & money.
View huff's profile
huff
2828 posts in 3191 days
#3 posted 11-11-2009 12:14 AM
Bill, MedicKen covered it pretty well. Lacquer dries fast, so if you try to apply too thin of a coat, it will not have time to flow out, which will leave streaks, etc. If you’ve had good luck with polyurethane, I would stay with that. Polyurethane is a much more durable finish than lacquer (especially a brush lacquer, which is a straight nitrocelluous lacquer and is not a hard finish and does not protect against moisture or chemicals very well. Easy to apply and easy to repair, but limited on durability. A catalyzed lacquer is much more durable, but that has to be sprayed.
-- John @ http://www.thehuffordfurnituregroup.com
bill1352
#4 posted 11-11-2009 04:16 AM
Thanks Huff. I had the idea in my head that the brush on was about the same as the spray on in hardness. back to poly i guess.
