Would like Some Input About A Finish
Forum topic by Sawdustmaker115 posted 08-28-2015 01:24 AM 912 views 0 times favorited 3 replies Add to Favorites Watch
View Sawdustmaker115's profile
Sawdustmaker115
306 posts in 1595 days
08-28-2015 01:24 AM
Topic tags/keywords: question finishing
I’m getting sick of using rattle cans for spraying lacquer because I’m in a basement shop plus I’m getting sick of the smell, not mention the inconsistencies of the spray. So I would like some input on General Finishes Enduro WATER BASE LACQUER . I also would like some opinions about which gun I should get, I don’t really won’t to spend anymore then $100.00 on a new gun I have a 60gal air compressor so having enough air is not an issue. I was thinking about just getting a cheap HF gun to start so I can save up some money to buy a better gun/system. What do you guys think of this gun from HF? Will it spray the WB lacquer okay?
-- Anthony--http://knottywoodshop.weebly.com/
3 replies so far
View pjones46's profile
pjones46
997 posts in 2516 days
#1 posted 08-28-2015 04:42 AM
Problem with HF products like the spray gun is that you can’t get replacement parts or accessories such as needle valves and tips. A cheap spay gun is like comparing the finish you get with a cheap chip brush to an expensive one.
-- Respectfully, Paul
View Aj2's profile
Aj2
1226 posts in 1671 days
#2 posted 08-28-2015 05:22 AM
I use Generals water based laquer and like it it’s very clear,Doesn’t have a Amber tone at all.Its not as clear as tru nitro laquer.And still wear a respirator it’s pretty bad to breathe.
I also use the sanding sealer first to close out the wood cells.If I were you pass on the harbor freight gun.And save up for a 3m accrupray gun with the tip Thats recommended.
Good luck.
-- Aj
View Shadowrider's profile
Shadowrider
183 posts in 1083 days
#3 posted 08-28-2015 05:47 AM
I got one of these. Haven’t used it for woodworking yet but it sprays pretty nice with automotive clear coats. I have no doubt that it will spray a professional finish with the right tip and adjustments. And GF stuff is awesome, that laquer will do fine.
http://www.lowes.com/ProductDisplay?partNumber=301329-47120-SGY-AIR88TZ&langId=-1&storeId=10151&productId=50129826&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
