Spline cuts
Forum topic by Dudley posted 12 days ago 217 views 0 times favorited 6 replies Add to Favorites Watch
View Dudley's profile
Dudley
340 posts in 151 days
12 days ago
Topic tags/keywords: tip
What blade do you folks use to make the spline cuts? TKS.
-- Dudley Young USN Ret.
View Gene Howe's profile
Gene Howe
331 posts in 319 days
11 days ago
I use a Tenryu rip blade. New (not yet sharpened), it yields an exact 1/8” kerf.
I use a thin kerf rip blade but, not for splines.
How do you mill your spline stock?
-- Gene
View mnorusis's profile
mnorusis
46 posts in 34 days
11 days ago
I’m curious about this too. I used my freud glue-line rip blade, but the cut is slightly rounded in the bottom (top of the blade), so I would imagine there is a better choice?
Dudley
11 days ago
I rip the spline stock on the table saw a little over size and run it through the planer. Would the outside blade of my dado set cut the spline square at the bottom? I made a good spline jig.
View childress's profile
childress
162 posts in 433 days
11 days ago
Yes! I use my dado blade… one of the end ones.
-- Childress Woodworks
View bentlyj's profile
bentlyj
783 posts in 361 days
11 days ago
Depending on what I’m doing, I’ll use a 3 wing slot cutter in my router.
View tblrxdave's profile
tblrxdave
17 posts in 184 days
10 days ago
I sure would like to see a picture of Dudley’s spline jig. I’ve used a shop-made saddle fence on my table saw.
