I recently purchased from a local widow my first hybrid table saw, a 2009 Hitachi C10FL. It had been sitting idle for a few years, so there was much cleaning and adjusting to be done. I'm at the tail end of all that, and in running test cuts it occurred to me how 'tall' this saw is on its factory stand, approximately 36 inches. My other contractor table saw (only three years old) is on a base I built that brings it up to a comfy 32 inches high. I am only 5' 6" with an inseam barely 29 inches. The Hitachi feels awkward. I really don't like the way I have to stretch my arms past the blade. I have no choice but to make a wooden base and get help in transferring the body over to it.
So my question: is there a rule of thumb, a standard understanding, on how to gauge what the height of the table saw top should be in relation to your waist?
I encountered a similar problem when I raised my new Hammer K-3 table saw about 5 inches when I added heavy duty casters so I could re-position it in the shop to accommodate long or large boards or plywood. It felt very "unnatural" at the increased height, but I soon got used to it and now don't even think about it. You do have a point about reaching over the saw blade. My best advise is develop habits of movement of your arm anywhere near the saw blade. I have been working around table saws for over a half a century with no nips due to always being careful and using developed exaggerated arm movements to keep well clear of the blade.
If you can't lower the saw, maybe making a raised platform to stand on while using the saw would be an option.
There probably is, and I don't know what it would be. But let me say, I'm pretty close to your overall height (I'm 5'7") and the table saws I've had were all right at the 36" table height. I've not had any problem with it, maybe because I just got used to it or have never used anything else. Anyway, I don't think your platform idea will be safe…unless it's screwed to the floor. The though of it moving in use, or you taking a step to the edge of it and losing your balance sounds like a real possibility. I'd try using the saw awhile and see if it starts to feel more comfortable over time.
I hadn't thought of building a stool or platform, even as a temporary solution to gauge what height works best for me. I'll have to see what room I have for one and how I could make it safe. Thanks.
I encountered a similar problem when I raised my new Hammer K-3 table saw about 5 inches when I added heavy duty casters so I could re-position it in the shop to accommodate long or large boards or plywood. It felt very "unnatural" at the increased height, but I soon got used to it and now don t even think about it. You do have a point about reaching over the saw blade. My best advise is develop habits of movement of your arm anywhere near the saw blade. I have been working around table saws for over a half a century with no nips due to always being careful and using developed exaggerated arm movements to keep well clear of the blade.
If you can t lower the saw, maybe making a raised platform to stand on while using the saw would be an option.
I know how getting use to how things default to makes them feel comfortable over time. In this case, I don't see how I would be able to use a box joint jig, where I plan on looking over the process, at the saw's height. I also noticed that where the throw-off from the spinning blade would hit me in the chest and arm on the contractor saw it now throws the sawdust into my face. A few inches seems to matter?
A stout platform may be a good way to see if it matters. Thanks.
There probably is, and I don t know what it would be. But let me say, I m pretty close to your overall height (I m 5 7") and the table saws I ve had were all right at the 36" table height. I ve not had any problem with it, maybe because I just got used to it or have never used anything else. Anyway, I don t think your platform idea will be safe…unless it s screwed to the floor. The though of it moving in use, or you taking a step to the edge of it and losing your balance sounds like a real possibility. I d try using the saw awhile and see if it starts to feel more comfortable over time.
Appreciate your input, Fred, especially because you are roughly my height. You raise good points on the potential safety hazards of using a raised platform. For testing purposes I think I can make it safe enough. If it turns out that the difference in height works for me, I would want to either cut down the steel legs and remount (drill new bolt holes) the elevating casters or build a new wooden base and move it over when done. The saw is about 260 lbs. It was all I could do to flip it over on my own without hurting myself. I really don't have anyone here to help, so that's the best reason for looking for a solution that doesn't require modifying the stand height. I guess more time on the saw and some thinking needed.
Thought I'd wait sto see what was posted before posting this:
In an ideal world, you could stand at your saw with you arms relaxed at your side, raise your hands so they're parallel with the floor, and your palms would be at the desired tablesaw table height. In other words, the saw's height should allow you to get upper body leverage over the work, so you can push stock in comfort and with better control using your upper body weight, and not your arm muscles.
In the real world, I look at all the other table surfaces in my shop, and try to get them to line up with each other. For example, a mobile outfeed table should be the same height, or a hair under, the saw's height; your router table may be nearby and shouldn't be higher that the saw so it won't interfere with processing sheet goods; you may keep you jointer near the saw (which is very handy during milling operations) and its fence may get in the way if it's higher that the saw; a workbench makes a good outfeed or sidefeed table and shouldn't be higher than the saw. You get the idea.
From my experience, 34 in. or 34 1/2 in. are the 'standard' tablesaw heights you'll find in most shops. Mobile bases typically raise that height to an uncomfortable level, and unless you're 6'6", I suspect your own saw is too high at 38 in. Some woodworkers get around this by nailing work platforms to the floor around their saws, or by adding really thick floor mats. Others forgo the standard commercial mobile bases and build their own devices that allow the saw to sit on the floor without raising its factory height; a wheeled, pivoting mechanism drops down and levers the saw off the floor when you need to move it. There have been some clever designs published in the magazine over the years. Why not search the Fine Woodworking archives to see if there's a design that suits your needs? Try searching 'mobile bases' and let us know what you find.
The correct height is the one you are comfortable with. I am 6' 3" with a bad back and like my tools high. I have built platforms in mobile bases to raise them. They would not be good for many people.
The best advice you have been given is to try different heights and find the best one for you.
To add, the question for me is: when you have pushed the stock past the blade, do you feel comfortable and in control? If not, then you need to do something.
That Hitachi has L shaped sheet metal legs with casters attached, right? One more rad solution would be to shorten the legs and reposition the castors. It would be a big job and need to be done carefully, but it's not that complicated, I wouldn't think. Unlike a stand, you can't undo it.
I talked about a platform on LJs for my daughter, who is skilled with tools but short, to use the table saw. There just has to be zero chance the platform will move, especially when the user is leaned over the saw.
Thought I d wait to see what was posted before posting this:
In an ideal world, you could stand at your saw with you arms relaxed at your side, raise your hands so they're parallel with the floor, and your palms would be at the desired tablesaw table height. In other words, the saw's height should allow you to get upper body leverage over the work, so you can push stock in comfort and with better control using your upper body weight, and not your arm muscles….
Thanks for the quote and link to the forum response, Ted. I have a leverage problem as it is right now. My waist line is below the top, so when I lean over the saw to push stock past the blade I am pressing my stomach against the front fence rail. I am fully extended, as well. This is workable for now, but I don't feel as safe as I could be without that extra few inches of height limiting how far I can lean over the top.
The correct height is the one you are comfortable with. I am 6 3" with a bad back and like my tools high. I have built platforms in mobile bases to raise them. They would not be good for many people.
Agreed. Comfort with control is an important part of safety. I don't feel I have that right now.
That Hitachi has L shaped sheet metal legs with casters attached, right? One more rad solution would be to shorten the legs and reposition the castors. It would be a big job and need to be done carefully, but it s not that complicated, I wouldn t think. Unlike a stand, you can t undo it.
This is the solution idea foremost in my mind right now, Charles. After deciding what height works best for me (and from the other saw's position, made that way purposely with the base I made for it), I can jack up one side, shorten the leg by that amount, drill new carriage bolt hole for the casters, and then do the same to the other side. Sure, if I ever decide to sell the saw this modification goes with it. I really don't care about the the next owner's needs. I am actually shrinking with age, not growing taller, so this isn't a concern to me. As you have said, a bit of work is involved. I have an angle grinder and HD 1/2" corded power drill, so I think once jacked up this is just a matter of applying the correct tool to the task. The alternative, making a new base for it, requires someone to help me lift the saw off the old base to place it onto the new one. There is really only myself and I already know I can't lift the saw off the base by myself. Help is hard to come by, too.
[/QUOTE]
Making up a temporary platform is doable for me. the uneven and heavily pitted cement floor would make it impossible to lay one down and have it not rock or move. I mean, I would install levelers on the corners, which makes the who project seem like a waste of time. The best solution so far appears me to be the cutting down of the factory priced stand's legs and remounting the casters.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
