No Bandsaw, what's your preferred half lap technique?
« back to Joinery forum
Forum topic by savan posted 08-27-2015 02:23 PM 1265 views 0 times favorited 21 replies Add to Favorites Watch
View savan's profile
savan
97 posts in 2358 days
08-27-2015 02:23 PM
I’ve found myself building some cases lately and to save money I’ll use a 1×4 skeleton on the interior instead of a full piece of plywood.
For example if the cabinet has 2 columns of drawers I’ll use a rectangular 1×4 frame instead of plywood in the center to mount the drawer runners/slides on. The frame would be assembled using half laps. These are kind of a pain without a bandsaw.
What’s your favorite alternative to the bandsaw when cutting half laps?
21 replies so far
View jmartel's profile
jmartel
7807 posts in 2117 days
#1 posted 08-27-2015 02:24 PM
Tablesaw with a blade with a flat top grind.
Handsaw with a chisel and a router plane when I don’t feel like making noise.
I don’t use the bandsaw for half-laps.
4954 posts in 2460 days
#2 posted 08-27-2015 02:26 PM
I also use the TS, normally with the dado blade.
View boisdearc's profile
boisdearc
44 posts in 1302 days
#3 posted 08-27-2015 02:39 PM
Set the TS blade to correct depth….. If you don’t have a dado blade, you could make several passes with the miter gauge. Hope this helps.. Ron
View Richard's profile
Richard
1916 posts in 2657 days
#4 posted 08-27-2015 02:49 PM
- Fred Hargis
+1 Best way to do it , never used a Band saw for them either.
View Richard H's profile
Richard H
489 posts in 1647 days
#5 posted 08-27-2015 03:04 PM
I have never liked the surface I get from any of my tablesaw blades. The edges of the joint always look rough to me. It might be my dado stack and more expensive ones might give better results but the under $100 set I have does not. What I do is use the dado stack to get close than use a shoulder or rabbiting block plane to clean up the cheeks. You don’t have to remove much to turn a rough edge into a smooth perfect fit. It has the added bonus of not having to fuss with the settings so much as you only have to get close and remove the exact amount you want 1/1000 of a inch at a time.
View Mattyboy's profile
Mattyboy
50 posts in 1045 days
#6 posted 08-27-2015 04:16 PM
Agree with JMartel. Handsaw and router plane. When you mark your saw cuts with a knife line, it’s very accurate.
-- Matt, Northern CA
Richard
#7 posted 08-27-2015 07:39 PM
Agree with JMartel. Handsaw and router plane. When you mark your saw cuts with a knife line, it s very accurate.
- Mattyboy
Paul Sellers style , that man is the best I have seen at doing anything like this with a Knife Line and Chisel and or Handsaw .
View CharlesA's profile
CharlesA
3312 posts in 1764 days
#8 posted 08-27-2015 07:46 PM
A router plane? What percentage of woodworkers, do you think, have a router plane? I’m guessing < 10%, maybe < 5%.
Assuming the OP is part of the vast unwashed who don’t own a router plane, I would second the table saw with standard blade or dado—it can be cleaned up with a chisel.
View JayT's profile
JayT
5589 posts in 2178 days
#9 posted 08-27-2015 07:51 PM
A router plane? What percentage of woodworkers, to you think, have a router plane?
- CharlesA
Any of them with a chisel and a scrap of wood can have a router plane.
https://www.youtube.com/watch?v=B_2a_FwjAgk
That said, I’ll keep my Stanley #71, thank you. It gets used a lot and is the handiest of all the joinery planes.
View Mosquito's profile
Mosquito
9280 posts in 2259 days
#10 posted 08-27-2015 07:55 PM
+1 on handsaw and router plane from me as well.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View theoldfart's profile
theoldfart
9616 posts in 2418 days
#11 posted 08-27-2015 07:57 PM
Mitre box and chisel. Gives you the ability to do repeatable cuts accurately.
No noise, not much sawdust, and a relaxed pace. You can see your cuts as your doing them.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
jmartel
#12 posted 08-27-2015 09:11 PM
A router plane? What percentage of woodworkers, do you think, have a router plane? I m guessing < 10%, maybe < 5%.
Assuming the OP is part of the vast unwashed who don t own a router plane, I would second the table saw with standard blade or dado—it can be cleaned up with a chisel.
- CharlesA
He asked how we did it. I gave my answer.
You can still cut it by hand and use a chisel for half-laps. No router plane needed. It does make it easier to get a level surface parallel to the faces of the boards, however.
If the OP is a typical all power-tool woodworker, then they can use a tablesaw and dado blade, flat top blade, or a standard blade and clean it up with a powered router.
View BJODay's profile
BJODay
526 posts in 1910 days
#13 posted 08-27-2015 09:20 PM
I have used a router table and a band saw. The router table gave a very clean surface, but you have to watch for tear-out. The BS was much faster, felt safer to me and did a good job if I didn’t rush it.
I hate using dado sets on my table saw. I’m a chicken that way but I would rather work slower and feel safer. I would guess the fastest and probably most efficient method is a dado set.
BJ
CharlesA
#14 posted 08-27-2015 09:21 PM
- jmartel
Fair enough.
View gfadvm's profile
gfadvm
14940 posts in 2657 days
#15 posted 08-27-2015 09:41 PM
Two ways to do these on the tablesaw: Dado blade or 2 cuts using the miter gauge and tenoning jig.
