| Forum topic by azor | posted 12 days ago | 176 views | 1 time favorited | 8 replies | ![]() |
12 days ago |
I am a real neophyte when it comes to finishing a stained project. I have built some small night stands [2] for our bedroom using red oak veneered plywood for the case and red oak regular wood for its doors. I cant seem to get the scratches off the doors because I cant see them [senior vision maybe?] at the sanding stage. I’ve used the trick of applying thinner to the surface and checking for scratches, but that does not show everything. It’s only after I have added my General Finish Gel Stain and one top coat of Arm-R-Seal Semi Gloss that the scratches appear. I have refinished the same door twice and still the scratches [perhaps new ones] show up. I sand with a porter cable 5 hole orbital sander to 150 grit then 220 with a pad sander by hand. The gel stain can says to sand only to 150 grit, however. Anyone have any tips on other technique I could use? -- It isn't as easy as the demos make it seem. |
