Router template help
Forum topic by sparrowsedge posted 08-25-2015 02:24 PM 913 views 0 times favorited 6 replies Add to Favorites Watch
View sparrowsedge's profile
sparrowsedge
1 post in 907 days
08-25-2015 02:24 PM
Topic tags/keywords: router template frame
Help! I know this is probably stupid easy and I am just really overthinking it but I am having trouble creating a square hole template. I am making a picture frame from one solid piece of wood. I cut my 3.5×5.5 square for viewing the photo. I am wanting to create a template for routing the 4×6 inch edge on the back where the glass and photo will sit.i am using a 1/2 inch straight bit and the distance from my bit to the end of my router plate is 1 5/8 inches. Someone help. Every template I have made is too small or too big.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1078 days
#1 posted 08-25-2015 02:33 PM
I make the template the desired size and then use a pattern bit cut it in multiple passes of increasing depth. The biggest secret is to make sure that the pattern is high enough to allow the bit to make each pass. You will also need to make the template large enough for the router to ride on it safely. I use a home made offset base of clear plastic so I can clean out the center part.
View pintodeluxe's profile
pintodeluxe
5565 posts in 2715 days
#2 posted 08-25-2015 11:14 PM
Once the hole is cut out, you can use a bearing guided rabbeting bit to cut the recess.
View Nicky's profile
Nicky
695 posts in 3993 days
#3 posted 08-26-2015 12:08 AM
1 5/8 + 1/2 = 2 1/8
A frame where the inside dimensions are 6 1/8 X 8 1/8 should produce a 4×6 rabbit.
I’m assuming your 1 5/8 is measured from the edge of the router bit to the edge of the base plate.
-- Nicky
View gfadvm's profile
gfadvm
14940 posts in 2591 days
#4 posted 08-26-2015 12:19 AM
- pintodeluxe
Yep, That’s how I would do it.
View bearkatwood's profile
bearkatwood
1476 posts in 913 days
#5 posted 08-26-2015 12:04 PM
Try making a template with a hole 7 1/4”x 9 1/4” and see what you get. You will have to square up the edges by hand, but this should work, I think.
-- Brian Noel
View leatherstocking's profile
leatherstocking
22 posts in 954 days
#6 posted 08-29-2015 05:18 AM
Yep, me too
-- John, BC, Canada. Wherever I go, there I am.
