Walnut Counter Tops Finishing
Forum topic by Chuck1685 posted 08-25-2015 02:00 PM 845 views 0 times favorited 4 replies Add to Favorites Watch
View Chuck1685's profile
Chuck1685
28 posts in 1052 days
08-25-2015 02:00 PM
Topic tags/keywords: question
Hello All,
So I am updating my kitchen and plan to use some 8/4 walnut I have had in the shop for about 4 years. My question is what type/brand of finish would be best? I don’t mind shelling out a little more money for higher quality. I don’t plan to do any cutting on them, so just something to seal and protect from normal usage. Any suggestions are greatly appreciated!
View mahdee's profile
mahdee
3870 posts in 1732 days
#1 posted 08-25-2015 07:04 PM
I would use polyurethane. Two light brushing and sanding in between and a heavy coat after a few days.
-- earthartandfoods.com
View chrisstef's profile
chrisstef
17307 posts in 2971 days
#2 posted 08-25-2015 07:21 PM
When I did the walnut tops in my old house I used Arm-R-Seal at the advice of Charles Neil. 5 coats in total on the top and 2 coats on the bottoms. You really need to let the finish cure for a good couple of weeks before putting them into hard use though. Another option would be Waterlox Original for oil based or General Finishes High Performance for a water based. Semi gloss would be my choice.
Some people have issues with semi gloss for the first couple of coats due to the flatteners in it causing streaking. Some wil lreccomend using a gloss for the first 2 coats then moving to a semi gloss for the last couple.
View Goatlocker's profile
Goatlocker
58 posts in 1937 days
#3 posted 08-31-2015 01:37 PM
I used the waterlox for my kitchen island with a 12/4 sapele top. It has been 2 years now and still looks great with only minor scratches. Note: I do not take it easy on it and wanted to get it beat up to add to the look but it really isn’t happening.
-- All tyranny needs to gain a foothold is for people of good conscience to remain silent - Thomas Jefferson
View bobasaurus's profile
bobasaurus
3405 posts in 3149 days
#4 posted 08-31-2015 09:02 PM
Any problem with waterlox reacting with soap when cleaning? I made some cherry soap dishes and finished with waterlox, and it seems to make a brown sludge anytime soapy water contacts the finish.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
