Anyone familiar with Japan drier?
Forum topic by Shopsmithtom posted 14 days ago 165 views 0 times favorited 7 replies Add to Favorites Watch
View Shopsmithtom's profile
Shopsmithtom
407 posts in 1086 days
14 days ago
Topic tags/keywords: finishes
Has anyone in the LJ world used Japan drier? Any experiences good or bad? While I’ve read several articles in which it’s used as an additive to speed drying, they don’t say how much faster stuff dries. They are even a bit vague on the ratios.
Also, while it says on the can to use w/ oil based paints, is it more universal? I know water based stuff is out, but are all other varnishes ok, or some not?
Specifically, I’m wondering if it can be added to boiled linseed oil to speed curing time, or even oil based stains, I suppose. Any best ratios for specific uses?
C’mon, Lumberjocks, fill me with knowledge! -SST
-- Accuracy is not in your power tool, it's in you
Beginningwoodworker
4090 posts in 564 days
14 days ago
Never heard of that.
-- CJIII Future cabinetmaker
View jcsterling's profile
jcsterling
68 posts in 476 days
14 days ago
I use about a cap full of japan drier when mixing BLO , turp , and varnish. Be sure to dispose of oily rags quicker than usual because the faster drying means it can generate more heat quicker thus potentially spontaneously combusting.
-- John , Central PA , www.jcsterling.com
Shopsmithtom
14 days ago
Interesting point on the rags, and one that can’t be stressed too much in the shop. I read an article, I think in FWW mag that did some temperature tests of linseed oil rags & while I know they’re an issue if you don’t hang them up to dry properly, & can combust, I was blown away by how fast the temp increases if left bunched up unattended. If Japan drier increases the speed…wow. Take some along when you’re camping in case your matches get wet.
View drgoodwood's profile
drgoodwood
381 posts in 1019 days
14 days ago
Note: BLO and most oil-based varnishes already contain metal drying agents.
DO NOT use Japan Drier with these products. It may be a waste of time or it can even cause the curing process to fail.
Japan Drier is meant to be used with raw oils, like raw linseed oil or tung oil. It has a dramatic effect with linseed oil but very little effect with tung oil.
It has little effect with respect to spontaneous combustion.
I’m a chemist with consulting experience in the wood finishing products and paints industry.
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
16548 posts in 468 days
14 days ago
Blo is not boiled it is linseed oil with dryers to help it dry quicker.
View RBWoodworker's profile
RBWoodworker
215 posts in 243 days
14 days ago
I will tell you all this much….
A few years back.. while working for my cousin..we used to stain out cabinets with a wipe on minwax stain or a lacquer based stain..I don’t remember which one he used at the time.. but my cousin, not thinking..left the rags in the shop..bunched up..pulled the work truck into the shop at the end of the day and left..only to get a call in the dead of the night saaying his shop was on fire!!..yes..that’s right.. the rags combusted and caught fire.. and within an hour..totally consumed the truck.. boring machine, edgebander and a few other machines and tools and the roof..the cause.. chemical combustion! he had no isurance.. no money saved for this disaster.. his machines were lost.. and the machines that the fire didn’t consume.. the water from the fire dept. hoses finished off.. it was a total lost.. it took me, moving all my machines from my shop at my house, into the adjoining buildings of his shop to keep the business afloat and moving forward..he never recovered from this disaster and my machines are still there being used and I don’t even work for him, but have full access to the shop to make my furniture..
SO.. please.. It would kill me to see another fellow woodworker go thru this ordeal, please discard your used oiley rags and solvent based rags in a sealed container of water..or.. completely lay them flat and hang them outside where they cannot catch anything on fire..
-- Randall Child
25788 posts in 1292 days
14 days ago
I make what I call my home made danish Oil. 1/3 BLO, 1/3 Varnish and 1/3 Mineral Spirits.
I then add 1/2 cap of Japan Drier.
I make sure I use it all up because it doesn’t keep after the Japan Drier is added.
I put it on my Maple Hall table.
Click for details
The oil was dry overnight. The next day I lightly sanded it with 400 grit and then paste wax. It shines with a nice semi gloss shine.
Japan dries is very easy. I used 1/3 cup of each of the parts so I used 1 cup of finish with the 1/2 cap of drier.
