| Forum topic by thedudeabides | posted 21 days ago | 157 views | 0 times favorited | 5 replies | ![]() |
21 days ago |
21 days ago |
Lignomat, Electrophysics and Wagner seem to be three highly regarded brands in the US, but all seem to be up around $200 plus. There’s lots of professional users, and lots of good info on the topic on Woodweb: http://www.woodweb.com/ As ever you can buy an eastern made meter for $30 – $50 depending on the deal you get, and people speak of getting good results with these too. I can’t make a recommendation as i’ve no experience yet of it in use, but i recently bought a Mini Ligno DX/C by Lignomat at just under $200 from Highland Woodworking – i paid the extra because it’s the kind of thing i wanted to buy once and forget about, and i’ve had very mixed experience with buying cheap stuff over the years. It’s certainly a very nicely made unit, it’s German, and it has a well designed, strong and compact looking external housing. I looked mostly at pin type meters. The Mini Ligno DX/C has a socket for an accessory accessory hammer in remote probe on a cable, and reads up to around 60% – both may be useful factors if you were ever thinking of going kiln drying – most of the cheaper units as far as i can remember read up only to around 20%. Ligno have a Mini Ligno with no probe socket and a narrower reading range which is cheaper. As best i could bottom the issue the non contact type meters are (a) typically more expensive, and (b) good for scanning larger areas in a hurry; but they have limits such as depth of penetration and the possibility of being thrown out by surface contamination. I more or less concluded that they were not strictly speaking alternatives, more that their abilities overlap but both types have unique abilities too. Lignomat i seem to remember had a deal going a few months ago where you could buy both together for a discount, but i don’t know if this is still on. Don’t take this as gospel, it’s just my take on what seemed to be coming out when i read around… ian -- Late awakener.... |
14 days ago |
ebay south korea digital 4 pin for 20 bucks. |
14 days ago |
Like most things in woodworking, it depends on what you intend to use it for. It’s been years since I’ve purchased wood in person at a mill but, if your intent is to check their lumber, you may avoid being sent down the road by showing up with a Delmhorst or something equivalent. Good ones aren’t cheap but, if you take care of them, they’re a once in a life-time purchase. |
14 days ago |
I just found the 4-pin meter on ebay and ordered it. For $20 it’s worth a shot. I don’t need one that’s super-accurate so I’m hoping this one does the trick. Thanks for the post! |
11 days ago |
glad to hear, i know guys that spent 2-3 hundred. |
| Forum | Topics |
Woodworking Skill Share
2924 |
3954 |
257 |
952 |
225 |
Woodworking Trade & Swap
621 |
Coffee Lounge
2396 |
LumberJocks.com Site Feedback
524 |
