Carbide Fostner Bits???
Forum topic by JTTHECLOCKMAN posted 14 days ago 220 views 0 times favorited 6 replies Add to Favorites Watch
View JTTHECLOCKMAN's profile
JTTHECLOCKMAN
8 posts in 41 days
14 days ago
Anyone out there use carbide fostner bits? If so what brand have you found to be better quality? How do they compare to HSS? I am drilling alot of high density acrylic billiard balls and HSS bits are wearing out very fast. I was thinking of carbide. Any other suggestions Also tried the titanium coated ones and they are not fairing well either. Thanks for the replys.
-- John T.
View Ger21's profile
Ger21
26 posts in 22 days
13 days ago
I’ve used Freud. I’m not really aware of any others, except for boring bits made for CNC machinery with 10mm shanks.
-- Gerry
View Kjuly's profile
Kjuly
84 posts in 177 days
13 days ago
I also have a Freud.
It holds an edge a lot longer than HSS.
I have to ask…What are you making with the billiard balls?
Keith
-- Keith, Charlotte, MI www.julyswoodworks.com www.TheBenchDawg.com
View mski's profile
mski
360 posts in 871 days
13 days ago
I got a Rockler one for hinges, works A+’
If you are drilling high density acrylic alot I would go for it, carbide isn’t as sharp but will last longer and I have no idea if you can resharpen those HSS bits without changing the size.
I have a carbide bandsaw blade that will hog through any wet or knotty log and keep going and going.
You might be able to diamond hone carbide without changing the size also.
My 2 c
Peace
-- MARK IN BOB, So. CAL
TopamaxSurvivor
2980 posts in 567 days
13 days ago
I have drilled them to make bowling balls for the dwarfs that live acorss the street.
View JasonWagner's profile
JasonWagner
88 posts in 71 days
13 days ago
ha ha…you mean “little people”
View ondablade's profile
ondablade
67 posts in 90 days
13 days ago
Here’s a page from Germany listing Famag’s carbide tipped Bormax3 Forstners about half way down. http://www.fine-tools.com/bohr4.htm They’re bloody expensive.
Here’s a set of carbide Forstners from Woodtek costing about 1/4 of the price: http://woodworker.com/fullpres.asp?PARTNUM=109-094&LARGEVIEW=ON
It’s quite hard to figure what’s what. There’s lots talked about the advantages of the much tougher higher quality fine grained carbide – but i never seem to be able to tell when it’s about paying for the brand, or about paying for quality.
I recently ended up buying a set of 15 of Famag’s series 1622 HSS Forstners, they were still very expensive but will hopefully be worth it – the carbides were just too rich for me….
ian
-- Late awakener....
