technique on removing nuts from router bits
Forum topic by juniorjock posted 15 days ago 102 views 0 times favorited 4 replies Add to Favorites Watch
View juniorjock's profile
juniorjock
790 posts in 657 days
15 days ago
Topic tags/keywords: router bits guide bearings
Haven’t had much experience with routers, but I need to ask you guys what technique you use to remove the nut from the end of a bit to change guide bearings?
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
View bentlyj's profile
bentlyj
783 posts in 362 days
15 days ago
It depends on the bit. But when there’s nothing to grab onto I have taken 2 pcs of wood and clamped together, then drilled a 3/16” hole down the middle, then place the bit (shank) in between the 2 pcs and put it in the vise.
View Kindlingmaker's profile (online now)
Kindlingmaker
1469 posts in 418 days
15 days ago
Place the bit in the router with it UNPLUGGED, lock the router rotation and use your wrench. Tighten it the same way.
25793 posts in 1292 days
15 days ago
I use wooded blocks in my vise and clamp the bit in there.
juniorjock
14 days ago
Thanks guys.
Karson – I tried the blocks in the vice and it didn’t work. KM – I also tried it in the router and it didn’t work.
The bit is a slot cutter with 1/4” shaft. I ended up putting vice grips on the thick part of the shaft and finally got the nut to turn. I know that doing this was a big “no-no”, but I need the nut off so I could change bearings. It was a brand new bit from Eagle Am. and I think the nut was so tight because it was new.
Next time, I’ll try bentlyj’s suggestion and see if I can get that to work. I don’t think the nut should be tightened that much.
