Mounting the Rails on a PM 66
Forum topic by Duffman posted 08-24-2015 11:00 PM 677 views 0 times favorited 8 replies Add to Favorites Watch
View Duffman's profile
Duffman
66 posts in 1325 days
08-24-2015 11:00 PM
Hey Guys,
I need some info. I purchased a PM66 and a set of rails, but there were no bolts to mount the rails to the saw. What size bolts do I need?
-- I'm not addicted to buying tools or wood... I can stop any time I want!
8 replies so far
View TheFridge's profile
TheFridge
9455 posts in 1483 days
#1 posted 08-24-2015 11:19 PM
Prob 1/4-20 countersinking Philips head. Or something like that.
View upinflames's profile
upinflames
217 posts in 2159 days
#2 posted 08-24-2015 11:45 PM
It depends on which fence rails, if they are round it takes a shoulder bolt and spacer, beis type takes standard hex bolts.
The round rail will use these, (minus the nut, this is for unisaw)
Duffman
#3 posted 08-25-2015 01:16 AM
i have the bies rails, with counter sunk holes
upinflames
#4 posted 08-25-2015 02:24 AM
Then it will be a tapered machine screw that fridge referenced.
MrUnix
6709 posts in 2196 days
#5 posted 08-25-2015 02:41 AM
The factory holes in the table are the same as on the Delta I believe, which are 3/8”-24. For mounting a Biesemeyer, those usually aren’t used and instead you need to drill 1/4 holes in the table to match the mounting holes on the rail, then use 1 inch long 1/4” flat head machine screws and nuts to secure to the table.
Biesemeyer Installation Instructions
Duffman
#6 posted 08-25-2015 03:17 AM
Awesome, thanks for the link Brad
-Ryan
MrUnix
#7 posted 08-25-2015 03:29 AM
Just realized… the manual above is for the older commercial fence/rail system, not the home shop version (which has smaller rails). Linked here just in case that is what you have instead:
Biesemeyer Home Shop Instruction Manual
Duffman
#8 posted 08-25-2015 03:47 AM
it would appear that my rails are for the commercial fence, not the home shop version, but thanks
