How to cut a live edge slab????
Forum topic by Aaron33 posted 08-24-2015 09:36 PM 3867 views 0 times favorited 14 replies Add to Favorites Watch
View Aaron33's profile
Aaron33
6 posts in 1208 days
08-24-2015 09:36 PM
Hello everyone I’m working on a live edge slab project and am getting conflicting information on how to cut the piece flush. I’m building an all live edge cedar bookshelf and really need help on how to properly mark and cut them. Thanks.
14 replies so far
View mahdee's profile
mahdee
4006 posts in 1940 days
#1 posted 08-24-2015 11:00 PM
Is it live edge on both sides? If so, mark the centers on both sides and draw a center line. Use your square against that line to determine your end cuts.
-- earthartandfoods.com
Aaron33
#2 posted 08-24-2015 11:07 PM
- mrjinx007
It’s live edge on both sides. I’m still unclear how to get the exact center line due to not have exactly the same size ends.
View gagewestern's profile
gagewestern
308 posts in 3523 days
#3 posted 08-24-2015 11:37 PM
Does not have to be center but get the grain to match on joint and the finished board the with you want.
-- gagewestern
Aaron33
#4 posted 08-24-2015 11:39 PM
- gagewestern
Thanks!!!
View gfadvm's profile
gfadvm
14940 posts in 2863 days
#5 posted 08-25-2015 12:29 AM
Aaron, I’m not sure if you are wanting to straight edge one edge of your slabs or if you want to square the ends???
Aaron33
#6 posted 08-25-2015 12:55 AM
I’m trying to square the ends.
View CharlesA's profile
CharlesA
3342 posts in 1970 days
#7 posted 08-25-2015 01:05 AM
- mrjinx007
It s live edge on both sides. I m still unclear how to get the exact center line due to not have exactly the same size ends.
- Aaron33
Isn’t that because a live edge piece doesn’t have an exact center line? Last time I did it, I spend a lot of time laying out the line, and adjust it a couple of times, but in the end, I just had to go ahead and cut it. There are poor ways to do it, but there is also no one exact perfect line/cut.
gfadvm
#8 posted 08-25-2015 01:20 AM
I would measure and mark the center on both ends, snap a center line with a chalkline connecting the marks on each end, and then use the square as Charles suggested.
View yvrdennis's profile
yvrdennis
48 posts in 1250 days
#9 posted 08-25-2015 01:23 AM
I’d use a long straight edge or a chalk line to mark a “centre line” where it looks about right, and then use a square to mark square cut lines at both ends. Cut with a hand saw. When you test assemble the piece you can adjust the cut on the ends with a hand plane.
Ymmv depending upon what tools you have. Depending upon the length of the shelf you could also use a sliding table or cross cut jig to do the end cuts on the table saw, but you’d need a secure way of clamping the workpiece down.
CharlesA
#10 posted 08-25-2015 01:42 AM
I got a good circular saw blade (Freud) and used a straight edge and got a really nice cut.
mahdee
#11 posted 08-25-2015 03:02 AM
I guess I should have said, measure the center on both ends instead of both sides.
Aaron33
#12 posted 08-26-2015 03:51 PM
Thanks everyone. I measured both ends, made a mark in the middle of the measurement and then popped a chalk line. Then i used a large square to mark my cuts. I measured over on my cut and kept taking the piece back to where it would be placed and kept trimming away to I achieved a snug fit. Starting to come together now. Thank you all for your help!!!
View tomsteve's profile
tomsteve
844 posts in 1392 days
#13 posted 08-26-2015 04:42 PM
ive used live edge for shelving both where the shelf is supported with brackets on the wall and in a shelving unit where they are supported on both ends. for the ones with brackets i didnt get complicated with the ends. what looked good worked for me.
for the shelving unit, which sides were also live edge, i built tbe unit then set the unit on the live edge slabs how i wanted the live edge to sit in tbe unit. marked the slabs along the inside edges and cut to length. worked out good and customer was happy.
Aaron33
#14 posted 08-27-2015 06:52 PM
Yeah what I did was build a frame to set the two upright sides in. Level them and then secure them so they would move as much while installing the shelves. I installed the bottom then the top in order to keep stability for the remainder shelves. Wood is always perfect no matter how much you plan or cut so I would measure over then take off 1\16 to 1\8 at a time until I could snuggly fit or lightly tap into place with a rubber mallet. Level the middle then the sides. Next I bored out large wholes, stopped halfway before going all the way through, use a smaller auger and went in enough to penetrate the shelving. Then I’m using screw in bolts and will hide with dowels.
