What can a band saw do?
Forum topic by Zuki posted 782 days ago 741 views 0 times favorited 24 replies Add to Favorites Watch
Rockler
View Zuki's profile
Zuki
1234 posts in 977 days
782 days ago
Topic tags/keywords: band saw
That might be a stupid question . . . but besides resawing and cutting curves . . . what else can be done with a bandsaw?
I was out looking at tools today and seen this puppy for $399 canadian. If memory serves it has ceramic guides. What do you think about the specs??
http://www.kingcanada.com/Products.htm?CD=13&ID=57
I have read the recent FWW guide on band saws, unfortunately the majority of saw are not available here in Newfoundland, . I am limited to Delta, King (link above) and Rigid.
View WayneC's profile
WayneC
6079 posts in 997 days
782 days ago
Things I am aware of….. You can use them to cut joints (dovetails/tennons). You can make bandsaw boxes. You can more safely cut stock that is thicker than your table saw. You can cut circles. There are ways to duplicate patterns on a bandsaw.
View GaryK's profile
GaryK
9555 posts in 888 days
782 days ago
You can make cabriole legs or other 3D objects. You can cut aluminum and brass.
With the thin kerf you can save making a lot of expensive sawdust.
It’s nice to have just to make small quick cuts that don’t really need a setup and you don’t want to
break down a setup on your tablesaw.
Gary
View mot's profile
mot
4904 posts in 936 days
782 days ago
Yeah, I have to agree with Gary. Though you can look at what else can it do, I think what can’t it do. It’s really a time and effort saver for making quick cuts, as well as resawing, cutting curves, making primary cuts for 3D objects, preparing blanks for the lathe, dealing with selection of parts of a board from within a board… it’s really useful around the shop. That King looks like a clone of the Ridgid. Most of those 14’s are almost the same saw save a couple of proprietary features.
GaryK
782 days ago
Hey Mot – I like the “What can’t you do with it” line. It about sums it up.
Gary
25871 posts in 1300 days
782 days ago
I use mine to make veneer and I also cut the shoulders on tenons with the table saw and cut the waste using the bandsaw.
View jerryw's profile
jerryw
105 posts in 816 days
754 days ago
my 14” bandsaw is the workhorse of my shop. i do 90% of my ripping on it plus all my resawing. i also have a 12” that i use for curves and circles. i would not give up my bandsaws.
-- jerryw-wva.
View Hicksiowa's profile
Hicksiowa
2 posts in 809 days
754 days ago
How about using a band saw to make Collapsible Castles? Check us out at www.CollapsibleCastles.com
Or check out our Flickr site at: www.flickr.com/photos/collapsiblecastles/
-Doug
View gizmodyne's profile
gizmodyne
1679 posts in 990 days
754 days ago
A. See Maloof.
B. See Krenov.My Understanding He had no tablesaw in his shop just a bandsaw and many planes.
Plus as the others said: Many joints can be cut on a bandsaw. You can use for ripping and then straighten with a jointer. Tenons, half laps, dovetails, scroll work.
I am not sure what I would give up first. Table saw or bandsaw? Hmmmm. I approve of your purchase Zuki.
View Dekker's profile
Dekker
145 posts in 780 days
754 days ago
As a new bandsaw owner, I can say that I bought the bandsaw to
  • cut curves
  • resaw thicker stock
You see, with the tablesaw, you are limited to cutting 2-3” thick material. With the bandsaw, you can cut much thicker material, and do it much safer since you can move slowly and don’t have to worry about kickback.
I use the miter saw for crosscuts, tablesaw for ripping thin or wide stock, and now I use the bandsaw to rip thick stock, or to create thin strips/veneer, or any of the other uses the other posters above have mentioned. I just wish i had more room for a larger bandsaw!
-- Dekker - http://www.WoodworkDetails.com/Blog/MNagy/
View Thos. Angle's profile
Thos. Angle
4013 posts in 862 days
753 days ago
Somewhere I read an article by Gary Rogowski about essential machines for the shop. He chose a band saw and left out the table saw. I think it was in FWW. His reasoning had to do with versatility. With a bandsaw, a router and a jointer you can acheive about anything. Add in chisels, handsaws and handplanes and you have a very functional small space shop. Add one of the small planers and the possiblities real surge. With this system a Skil type saw is almost essential for cutting boards down to size. Of Course, a sharp hand saw will make quick work of them as well.
-- Thos. Angle
View ben's profile
ben
158 posts in 770 days
753 days ago
When 4 siding rough lumber, can the bandsaw make the final parallel rip cut reliably? I (having not used one since high school) have it my head that the blade wanders too much to trust it for this task.
-b
Dekker
753 days ago
If properly adjusted, the blade will not wander, provided you use the correct blade and feed at the right speed.
Making the cut parallel is not the problem. Removing the blade marks from the wood is more the issue: you will need to hand-plane or sand the wood flat, or pass it lightly through a planer anyway.
gizmodyne
753 days ago
Even if your cut is not perfect you can true it with a planer or jointer or plane. Oh my.
3056 posts in 922 days
753 days ago
I watched the guy From Laguna take veneeer after veneer off the band saw 2with their new carbide tipped resaw blade.
You could get away with using it right off the saw if you wanted as it was smooth as a babys’ rump.
of course the blad is probably more than most weekend warriors can justify at $1.50 per inch.
Mine will be $200.00 US. ( $185.00 CDN)
I hate sanding,
Thos. Angle
753 days ago
Hey, who turned the exchange rate around??!!!
-- Thos. Angle
753 days ago
“Hey, who turned the exchange rate around??!!!”
The Bush admin as far as I can figure ;-)
Thos. Angle
753 days ago
Yeah, blame poor ol’ George W
-- Thos. Angle
View Drew1House's profile
Drew1House
425 posts in 988 days
753 days ago
Thats what happens when Canada elects a conservative… who is… and we elect one who is not… (fiscally)
Drew
-- Drew, Pleasant Grove, Utah
Dekker
753 days ago
The bookstores are raking in the $$ though… They’re still charging the “Canadian” price listed on the back cover, which is often 30-40% higher than the US price!!!
At least with tools, the gap is not that bad… usually
14188 posts in 1061 days
753 days ago
I just heard that Walmart is charging the American price on books, (here in Canada).
View miles125's profile
miles125
1443 posts in 905 days
753 days ago
Heres what you can do with a bandsaw!
View Donna Menke's profile
Donna Menke
103 posts in 1166 days
752 days ago
I went to look at the collapsible castles and I am amazed and agog. I thought I knew everything there was to know about using the band saw, and all the projects possible, so it was with chagrin that I saw these marvelous creations. I want to make one- right away. Are there any instructions/tutorials/plans around to do that? I can figure it out for myself, but I’m kinda busy right now. They are soooo koooool!!!
-- "So much wood. . .so little time!" www.woodworks-by-donna.com
Thos. Angle
752 days ago
No bull, Miles??
-- Thos. Angle
View Zuki's profile
Zuki
752 days ago
neat Miles. I have actually been eying a King bandsaw the last couple of weeks. 1hp with a decent fence for $599. A 5” riser with blade is another $70 and the mobile base is another $50.
