dust collectors
Forum topic by hunter82 posted 19 days ago 180 views 0 times favorited 2 replies Add to Favorites Watch
View hunter82's profile
hunter82
9 posts in 640 days
19 days ago
I am looking to get a dust collector. I am torn between the Grizzley and the Rockler.
http://www.grizzly.com/products/1-HP-Light-Duty-Dust-Collector/G1163
http://www.rockler.com/product.cfm?page=21255
The rockler has 650 cfm and the grizzley has 450 cfm. How important is that since I only run one machine at a time. Would there be much of a difference in the noise between these two.
Are these pretty good at what they do
I am just a weekend woodworker so it will not be running all day every day.
Or
Should I just stick with my shop vac.
Thanks for the help
View TheDane's profile
TheDane
209 posts in 559 days
19 days ago
I have a 650 cfm portable DC (ProTech) ... if I am working outside on the driveway, I use the ProTech. If I am in the garage/shop, I usually wind up using my ShopVac/Dust Deputy combo.
One problem with these portable DC’s is the bag they supply. Mine came with a 30-micron bag, which means that the finest dust (the most dangerous stuff to your lungs) was blowing right through the bag and back into the air. I bought a 5-micron bag for it (about $30) and that helped, but I think I get better results with a HEPA filter installed in my ShopVac.
I run an air cleaner (ShopVac 1030000) when I am working in the shop, and I notice that the filters in the air cleaner seem to collect more dust when I am using the ProTech than when I use the ShopVac/Dust Deputy.
Very unscientific … but that’s how I see it.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
View MedicKen's profile
MedicKen
468 posts in 358 days
19 days ago
You may want to consider going a little larger than 650 cfm. If you ever upgrade your equipment or move to a larger shop and have longer runs of ducting you will be glad you did. My feeling is the smallest you would ever want to go is 650cfm and that is connected to 1 machiine with no more than 10’ of ducting. I would look at machines that are mininum of 1 1/2 hp with a 13” or larger impeller. You might also consider looking at FWW and WOOD magazines as they have both done reviews on dust collectors in the past year.
