Zero clearance throat plate
Forum topic by Dudley posted 16 days ago 181 views 0 times favorited 7 replies Add to Favorites Watch
View Dudley's profile
Dudley
344 posts in 152 days
16 days ago
Topic tags/keywords: jig
A while back I mentioned I made a 0 clearance plate out of 1/8” lexan. Don’t do it, it don’t last. Needs to be thicker. Sorry bout dat.
-- Dudley Young USN Ret.
TopamaxSurvivor
2994 posts in 568 days
16 days ago
Thanks for the tip.
16577 posts in 469 days
16 days ago
at least 1/4”
View GaryK's profile
GaryK
9521 posts in 880 days
16 days ago
3/8” even better!
View papadan's profile
papadan
440 posts in 260 days
15 days ago
My saw uses a 5/16” insert. I make mine out os scraps of laminate flooring.
-- Dan-- Info for all @ http://www.hoistman.com
View TheDane's profile
TheDane
195 posts in 555 days
15 days ago
I’ve had good results using 1/4” phenolic, but it is a little pricey. I think I’ll try Dan’s suggestion … I have 2 boxes of laminate flooring left over from the family room project.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
View ondablade's profile
ondablade
67 posts in 90 days
15 days ago
I guess the issue is possibly that no matter what you make your insert from it’s going to get chewed up by changes in blade setting and need replacing….
-- Late awakener....
View gerrym526's profile
gerrym526
132 posts in 700 days
15 days ago
Why not make a bunch of zero clearance plates?
I use osage orange wood, very dense and has a slight oily feel to the wood. Have made several zero clearance plates for my standard table saw blade, and for 1/4”, 1/2”, 3/4” dado blades. Also made one for my molding head set up.
-- Gerry
