Ugly stumps
Forum topic by Monkeyandafootball posted 08-23-2015 06:27 PM 1460 views 0 times favorited 26 replies Add to Favorites Watch
View Monkeyandafootball's profile
Monkeyandafootball
14 posts in 1035 days
08-23-2015 06:27 PM
Topic tags/keywords: stump stump tables side table danish oil
ok, so first off i am DEF a newbie, a clueless newbie at that. I am attempting to make some stump side tables and i have run into a problem i cannot seem to google myself out of. After sanding my black walnut limb pieces to death, i applied a coat of WATCO danish oil finish. and theyre ugly. dark and ugly:
http://i927.photobucket.com/albums/ad115/stumpie3/Mobile%20Uploads/image_zpspyr6sps6.jpg so i waited 2 days and resanded in an attempt to get the danish oil finish off. heres one resanded:
http://i927.photobucket.com/albums/ad115/stumpie3/Mobile%20Uploads/image_zps8r13bllz.jpg id like the stumps to have a nice natural finish, not a dark stained look like the danish oil stuff gave them….so i was hoping to resand and then just poly them (?). problem is, after resanding one of the stumps in order to get back to bare wood, the top looks horribly cloudy. when i wipe it off with a damp rag its beautiful, like this:
http://i927.photobucket.com/albums/ad115/stumpie3/Mobile%20Uploads/image_zpsqqxtg751.jpg but when it dries it loses all of its detail and just looks like a cloudy mess like this:
http://i927.photobucket.com/albums/ad115/stumpie3/Mobile%20Uploads/image_zpsroou73qb.jpg
so i guess my question is, if i poly the stump will it look “wet”” and defined, or will i just be sealing in the cloudy mess? thanks for any help and advice!
26 replies so far
View AlaskaGuy's profile
AlaskaGuy
4215 posts in 2337 days
#1 posted 08-23-2015 06:40 PM
You forgot the number 1 rule of finishing. “try it on scraps first”.
Monkeyandafootball
#2 posted 08-23-2015 06:42 PM
ahh, its not that i forgot it, i never knew it! im learning my lessons the hard way thats for sure :/
View JoeinGa's profile
JoeinGa
7736 posts in 2035 days
#3 posted 08-23-2015 06:58 PM
The wood has really sucked in that oil. Any chance you still have enough height to saw off an inch and start over?
View mahdee's profile
mahdee
3890 posts in 1795 days
#4 posted 08-23-2015 07:03 PM
They look just fine. If you are going to use them outdoors, use Zar outdoor poly. A little spray of poly on top should give you an idea of the look you’re going to get. My guess is that you will be happy with it.
-- earthartandfoods.com
Monkeyandafootball
#5 posted 08-23-2015 07:07 PM
sure, theres height to work with. the problem is the “heartwood”(?) of the black walnut is hard as concrete! sanding the sides is easy enuf, but the top is another story (especially for a girl weighing in at 88 lbs!)
im planning on using them indoors. i guess im just confused about why the top looks cloudy when dry and so pretty when wet…and what the final result will look if i just poly them (after resanding them).
JoeinGa
#6 posted 08-23-2015 07:17 PM
Ok, then try sanding the “bottoms” and do a test on that end. Use the oil on one, and do one with no oil. Spray a coat or 2 of clear lacquer and see which one you like best. If they come out fine, maybe the end you show in your pictures can become the bottom.
Oh, and WELCOME to LJs !
Monkeyandafootball
#7 posted 08-23-2015 07:18 PM
oh wait, you mean saw off an inch of the top like with a chainsaw and start over? cant do that, i dont have a chainsaw and theres no way i have the manstrength it would require to saw it off by hand, so sanding is my only option.
Monkeyandafootball
#8 posted 08-23-2015 07:20 PM
that is a great idea joeinga, except for the fact that i planned (and still plan) on painting the bottom halves of the stumps and decided to use ugly white woodfiller in the gouges i made debarking them on the lower halves :O
JoeinGa
#9 posted 08-23-2015 07:24 PM
Well, you might still be able to sand the bottom and shoot it with a coat of clear lacquer as a test run to see how the top will look.
Monkeyandafootball
#10 posted 08-23-2015 07:25 PM
Monkeyandafootball
#11 posted 08-23-2015 07:59 PM
i vacuumed the top of the stump i resanded and did a test swipe of some clear poly:
http://i927.photobucket.com/albums/ad115/stumpie3/Mobile%20Uploads/image_zpsqbd6mwpu.jpg
if thats how itll look finished i think ill be happy with that :)
once i finish resanding the other 2 stumps, i am going to paint the bottom halves with a black gloss enamel latex, im trying to go for a rustic meets modern thing….trying…
View jerryminer's profile
jerryminer
928 posts in 1469 days
#12 posted 08-23-2015 08:22 PM
Short answer, yes the “wet look” is what poly will leave you with, in general. Always good to test on scrap (or the bottom, before you paint)
Monkeyandafootball
#13 posted 08-23-2015 08:27 PM
thanks for all the input. ive learned my lesson to “test” before diving in, or just listening to the dude at lowes who sold me the danish oil telling me it wouldnt change the look of my stumps very much! I used the “natural” danish oil finish and was just shocked to see how orange they turned. maybe it had something to do with how dry the stumps were? i dried them for over a year before i started on them.
View Clarkie's profile
Clarkie
455 posts in 1869 days
#14 posted 08-23-2015 08:31 PM
How about flipping the logs end for end and starting over. The thing with Watco oil, which is a great product, is that it goes to the center of the wood and starts filling from there out. You can get a clear Watco, and Watco can be cut with poly and applied by hand, 50/50 mix.
View esmthin's profile
esmthin
77 posts in 1209 days
#15 posted 08-24-2015 03:42 AM
I think the problem is that you are doing this on end grain. End grain tends to soak in moisture more than long grain, so you get a darker color than expected.
-- Ethan, https://instagram.com/ethan_woodworker/
