Species for table legs and apron
Forum topic by oliussw posted 08-23-2015 03:47 PM 994 views 0 times favorited 8 replies Add to Favorites Watch
View oliussw's profile
oliussw
6 posts in 1220 days
08-23-2015 03:47 PM
I am a newer woodworker and lurker on this site for several months. I am currently working on a live edge dining table for my family. I have the table top glued up and at the sanding stage. It is made of wormy butternut and has a lot of character. The design my wife picked out calls for a apron and legs painted white. She thinks it will go well with our wainscoting and I defer to her on all matters of style. I had planned to use poplar for the legs and apron but recently read several threads where people talked about the poplar not being durable enough for such a task. We do still have small children in the home and I’m sure the table will see its fair share of abuse over the years.
Do you think I would be better served to go with a harder hardwood or will poplar do what I need it to?
8 replies so far
View bearkatwood's profile
bearkatwood
1619 posts in 1096 days
#1 posted 08-23-2015 04:00 PM
Maple would be my first choice.
-- Brian Noel
View bondogaposis's profile
bondogaposis
4898 posts in 2435 days
#2 posted 08-23-2015 04:13 PM
Soft maple would a good choice as well, but more expensive. I think that poplar would be fine also. It is plenty strong, it is a bit soft so, subject to getting dings. Using proper joinery and allowing for wood movement in the top you should be able to construct a table that will last more than one lifetime.
-- Bondo Gaposis
View pmayer's profile
pmayer
1028 posts in 3149 days
#3 posted 08-23-2015 04:36 PM
Poplar will work fine for the legs an apron. It is somewhat soft, but it is harder than butternut. I would be MUCH more concerned about using butternut for the top. Butternut is beautiful, but from a durability perspective you would be better off using nearly anything else.
View TheFridge's profile
TheFridge
9860 posts in 1570 days
#4 posted 08-23-2015 04:51 PM
I wouldn’t use poplar. Way too soft.
Maple would be my next choice.
pmayer
#5 posted 08-23-2015 08:59 PM
Perhaps you should clarify what you mean by “not being durable enough for such a task” and “will poplar do what I need it to?”
If your question is “will poplar hold up structurally as a table base, providing sufficient strength without failing under the typical load placed on it for this application”, then the answer is absolutely yes. Poplar is used all the time in paint grade furniture applications and will provide plenty of strength for this project assuming that you use it in appropriate dimensions.
If your question is “will poplar still look perfect if a kid drives a toy car into it or hits it with a golf club?”. Then the answer is ‘no’. Poplar has a janka rating of 540 which makes it one of the softest commercially available hardwoods. You can press your fingernail into it fairly easily, so it is definitely prone to dings. That said, it is used commonly for paint grade furniture and as a secondary wood because it machines and sands nicely and it takes paint extremely well.
Butternut, on the other hand, has a janka rating of only 490, which puts it in the same hardness class as white fir. That’s where you wear and tear will really show. A painted base is easy to repair, but a live edge butternut top is much trickier. If I were building a dining table with a butternut top I would consider distressing it so that the inevitable new dings look like part of the design.
View bruc101's profile
bruc101
1228 posts in 3626 days
#6 posted 08-23-2015 10:12 PM
I’ve turned 100’s of table and island legs and made table frames using popular and never had any problems. The image is a farm house island I finished and was picked up last Thursday.
The only thing not popular was the Cherry top and drawer fronts. The drawers are dovetailed oak. I left the tool marks in the table at the owners request.
I start a farm house table tomorrow and will use a different leg, 4 1/2” popular, and popular frame also.
-- Bruce Free Plans http://plans.sawmillvalley.org
View WDHLT15's profile
WDHLT15
1762 posts in 2560 days
#7 posted 08-24-2015 12:37 AM
Yellow poplar will make a fine base for your table.
oliussw
#8 posted 08-24-2015 02:38 AM
Thank you for all the replies. The butternut top is wormy and has sever knot holes that will all be epoxy filled. It has a lot of natural “distressing”. My wife likes that look, which is how I ended up with hand scraped wood floors. We don’t get lot of butternut here on Oklahoma but the pieces I’ve worked with feel slightly harder than poplar. I know there’s some variance within the species but I can’t make a fingernail mark on the butternut where it’s no problem with poplar.
