Is that one router bit or two?
« back to Woodcarving forum
Forum topic by FrankWood posted 08-23-2015 09:14 AM 1626 views 0 times favorited 6 replies Add to Favorites Watch
View FrankWood's profile
FrankWood
4 posts in 1249 days
08-23-2015 09:14 AM
Topic tags/keywords: molding router help
For my current project I need to replace a vanity mirror panel with a molding on the top and bottom. I’m somewhat new to woodworking and have not seen this profile amongst the router bit catalogs. I presume I must make multiple passes. Any suggestions on router bits and sequence for the profile displayed below?
https://im1.shutterfly.com/media/47a5d603b3127ccee9b8ed21c37b00000030O0wEZNmjJszas2oPbz4O/cC/f%3D0/ls%3D00535362406220150823005149958.JPG/ps%3D50/r%3D0/rx%3D550/ry%3D400/
thanks,
Frank
View jerryminer's profile
jerryminer
944 posts in 1682 days
#1 posted 08-23-2015 06:22 PM
Frank—If you want an exact match, you may be looking at a custom bit (many bit manufacturer’s will make custom bits)—-but if you just want to get close you can try something like this:
Infinity bit
You will have to cut the rabbet for the mirror as a separate step.
FrankWood
#2 posted 08-24-2015 03:49 PM
Thank you Jerry. My problem is I don’t yet know the names for various shapes and whether they are common ones or not. If it is a custom bit I’ll just aim for ‘close.’
In the interest of reuse I try to buy rather generic router bits. Is the infinity often used for other things? Would getting a convex shaped router bit (to make the nearly concave middle part) and then do the straight edges and rabbet on the table saw give me OK results?
With hand sanding I can hopefully get it close. Fortunately I’m only missing one door.
View Richard's profile
Richard
1922 posts in 2931 days
#3 posted 08-24-2015 04:53 PM
Frank , the Infinity is just one Brand of bit with the same profile as the one shown and you can use that bit for a lot of other projects that you want a different profile on than just a standard round over or cove.
Plus you can make a lot of different profiles on the router table just by using multiple bits and cuts at different height and fence settings. Sometimes I like to take some scrap wood and just play with some of the different setups to see what I can come up with.
jerryminer
#4 posted 08-25-2015 12:19 AM
Here is another approach, using two bits that are more “generic” in nature and may serve you better on future projects, (But router bits are a little like clamps——a guy can never have too many.)
I’m only guessing at your dimensions, so you may have to assess the right bit sizes.
Here’s a link to the Amana bit:
Amana Bits
FrankWood
#5 posted 08-25-2015 09:18 PM
Thanks. That looks like it will get me close enough. I have the roundover and need to get the convex one. I presume that will have many uses in the future.
FrankWood
#6 posted 08-08-2017 05:48 PM
Thanks to all who helped. I was able to get my molding reasonably close using the convex bit and some careful table saw cuts. With young children at home it took me about 6 months to do the task and another 18 months to finish this thread:)
