Why ground a Plastic dust collector ?
Forum topic by frostwood posted 17 days ago 188 views 0 times favorited 8 replies Add to Favorites Watch
View frostwood's profile
frostwood
34 posts in 80 days
17 days ago
I am alittle mistified as to why Dewalt includes a ground wire to ground the plastic dust collector hose on the attachment for the Dewalt 735 planer. The plastic looks to be a non conductive material but your thoughts.
-- With each new day, celebrate life. Love God with all of your heart. Share Jesus with those around you and make a positive impact on those you meet. Bob
View RexMcKinnon's profile (online now)
RexMcKinnon
658 posts in 88 days
17 days ago
This makes me wonder also. The ground is supposed to be from static with could possibly create a spark. I assume the hose is like a baloon. Rub it on your head and stick it too a wall.LOL I think saw dust moving in the hose would create the same effect. The part that gets me thinking is the ground is attached to one end. If the hose is non conductive how does it get rid of static on it’s entire length?
-- If all you have is a hammer, everything looks like a nail!
View Dez's profile
Dez
56 posts in 970 days
17 days ago
Grounding the static charge that can build up is a good idea. While I have never heard of a fire or explosion caused by a static discharge in a hobby shop, I have been shocked by the static buildup in a plastic collection hose!
Hurts a bunch and if your fingers were in the wrong place when it happened you could be seriously hurt!
(Zap, Jump, Zing and Bleed)
-- T.A.N.S.T.A.A.F.L.E.
View Dez's profile
Dez
17 days ago
On my drum sander I ended up applying aluminum tape the length of the hose and making sure the grounding wire was in good contact with it to stop the discharge. (the same aluminum tape HVAC folks use to seal their ducting)
I have been shocked as far as 12 inches away from the tube on my sander.
A buddy of mine used S&D for his system and where the collection pipe was close to the operator he would sometimes get shocked so he applied the same tape on the interior of the pipe to eliminate the discharge.
View RetiredCoastie's profile
RetiredCoastie
216 posts in 76 days
17 days ago
As air moves across plastic it causes a buildup or potential for static electricity and the ground gives the electricity a ground path to dissipate.
-- Eagles may soar, but weasels don't get sucked into jet engines! Mike D.
View MedicKen's profile (online now)
MedicKen
457 posts in 355 days
17 days ago
Static electricity is a real problem here. We have a very dry climate and its the perfect conditions for static. I have zapped myself more than once on the plastic hoses for my dust collector and shop vac. It smarts. I use my shop vac when I am using the router table and I must say there is more dust attached to the outside of the hose when I am finished as there is in the vacuum.
frostwood
34 posts in 80 days
17 days ago
Thanks to all for taking the time to reply. Very helpful.
View Kent Shepherd's profile (online now)
Kent Shepherd
805 posts in 179 days
16 days ago
We sold a Delta dust collector a while back. He complained about the lack of suction. I told him again that he needed to ground it. When he finally did, all was well. It was plastic pipe and static was the culprit.
frostwood
34 posts in 80 days
16 days ago
Actually mine is an ejection system on the 735 dewalt planer. It wound not make a difference I suppose as it is still dust moving through the plastic tube. I did go ahead a ground it. It is the new planer that I picked up on the clearance deal of $274.00 so I have not had an opportunity to use it as of yet.
