| Forum topic by pknight | posted 18 days ago | 114 views | 0 times favorited | 3 replies | ![]() |
18 days ago |
Ok ya’ll, I need a little bit of a bail out here. I’ve got some beech veneer going all squirly on me (apparently I didn’t soften it enough.) I’m using Titebond’s Cold Press and the veneer is trying to bubble and buckle. Currently have rolled down the entire surface, starting in the middle and paying attention to the joints to keep them as close as possible. The entire carcass assembly is currently under a MDF Platen and weighted with appx 250 lbs of sand (all the clean sand I had in the shop) my concern is that the weight I have applied will not be sufficent to flatten out the waves and bubbles that were developing (redeveloping!) as I put the platten on. Does anyone know if the cold press can be softened with a little heat and then repress just the loose sections? I know that a vacuum table would have been prefferable but that’s not budgeted until Jan! -- -Peter |
