| Forum topic by Kolmar | posted 18 days ago | 133 views | 0 times favorited | 6 replies | ![]() |
18 days ago |
I am having trouble with some mouldings i am doing, I have a problem when i do both ends at 45 degrees. I usually end up being too short. I line it up on my work piece and make my mark after I cut the 1st angle, I cut on the line, should i be cutting on the outside or is there a trick to marking and cutting i am missing. Do you use a refernce straight edge when you make your mark? I have been very inconsistent with my success. -- Kolmar |
