Dado Stack Recommendations
Forum topic by CharlieM1958 posted 16 days ago 254 views 1 time favorited 20 replies Add to Favorites Watch
7599 posts in 1110 days
16 days ago
With both my birthday and Christmas right around the corner, I’ve been thinking about treating myself to a decent quality dado set. My saw is a Ridgid TS3660 with 1.5 horsepower. I love the saw, but I realize it’s capabilities are somewhat limited by the low hp.
Given these facts, and the vast experience of my fellow LJ’s out there, I’m looking for suggestions for a set that would be a good match for my saw.
Thanks in advance!
View MedicKen's profile
MedicKen
452 posts in 354 days
16 days ago
I have the Freud 8” and it has been ok. It does leave nice clean shoulders but less than perfectly flat bottoms, especially in ply. SD508 I think is the model. If I had to do it over I may continue looking for other options. I bought the set a few years ago and it has been used on a Cman 1 1/2 hp hybrid saw, I have yet to set it up in my unisaw. I dont know if the extra hp would make a difference or not. I have heard good things about the Infinity and Forrest but they are a little spendy. Good luck and hopefully the family will make a good decision for you.
View rtb's profile
rtb
678 posts in 605 days
16 days ago
come on Charlie what have you tried to cut that your Rigid won’t handle. My 3650 has the same motorand they only time it slows down its generally me pushing to hard. OK I just brought home a 3in oak plank so at some time in the future I may change my mind but will probably consider changing to motor rather that the saw. I have the less expensive set of Freud dados and the saw has no problems at any width with any wood including hickory. This is around $100.000 +/- I have seen a couple of cheaper sets but I really have questions about the quality. I think that its a matter of how much as well as how often you really intend to use them. If I really expected to be using them every day I would probably consider other, more expensive and presumably better sets. But I don”t think that your saw is going to preform that much deferentially one way or the other sets will effect the saw one way or the other. If worse comes to worse ( and it hasn’t happened to me yet) you could always make multiable cuts. (same set as Medic Ken)
2372 posts in 233 days
16 days ago
i use the freud SD508 too ,
no probs . so far had it for 8 years ,
never sharpened .
still works great !
got it at
http://www.woodworkers.com
$199.00 ,
but they always match prices with anyone !
20538 posts in 714 days
16 days ago
First of all Charlie I think that you should go ahead and treat yourself to the Sawstop that was pictured. It would be a nice Christmas present and would handle any dado stack you wanted to run. :)
I run a Forrest set and get clean crisp shoulders and flat bottoms. I did run the same stack on my Craftsman 1.5hp saw without any problems (other than those inherent to the saw itself). Your Rigid will cut better than the Craftsman so you will not have any problems with running a dado stack. If you want to save a little money go with a 6” set rather than an 8”. Most dado cuts go no deeper than 3/4”.
16 days ago
RTB, I have not had any problem at all with my saw bogging down…. I’m well satisfied. I only brought it up because I thought it might play a factor in whether I should choose a 6” or an 8” dado, and if, in anyone’s experience, a certain model worked better on lighter-powered saws.
I don’t intend to use it all that much, but I’d rather pay a little more money for something that is going to make decent cuts when I do have a job that calls for it.
View dbhost's profile
dbhost
599 posts in 124 days
16 days ago
I believe Ridgid recommends a 6” Dado for that saw. I have the Oshlun SDS0630 6” stack which has been an insanely accurate dado. Laser sharp cuts, no ridges, flat flat flat bottoms… What more do you want? Oh yeah, calipers to dial in your cut width. Like most dadoes, the chippers are slightly undersized due to undersized plywood.
-- Trying to follow the example of the master.
View doyoulikegumwood's profile
doyoulikegumwood
276 posts in 884 days
16 days ago
howdy charlie i personally own to stack set the first is the dado king as scott said perfect dado’s every time all the time.
the second is a shop fox stack of all things and believe it or not it make great dado’s nice shoulders with a damn near flat bottom and for 40 bucks i cant complain.
happy hunting
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
16 days ago
Is the only advantage of an 8” over a 6” the depth of cut? I don’t see myself ever going deeper than 3/4”.
View John Gray's profile
John Gray
1748 posts in 777 days
16 days ago
Charlie I also have a Ridgid TS3660 and a 6” set of Craftsman’s stack. I’m not to happy with the Craftsman setup so I’ve been doing some research and from what I’ve found is that I will be purchasing the Oshlun SDS0630 6” stack very soon.
16 days ago
John,
I really think I’m leaning to that one as well. From the reviews I have read, and the reasonable price, it seems like the way to go.
16 days ago
Okay, I didn’t waste too much time on this decision. The Oshlun SDS-0630 it is. I just placed my order at Amazon for $58.99 with free shipping.
David, you may be right about the Freud, but I just can’t pry $200 from my moth-filled wallet for an occasional-use blade. :-)
View knotscott's profile
knotscott
521 posts in 267 days
16 days ago
Hi Charlie – I haven’t tried the Oshlun set but did own a Systimatic 42T/6T dado set that the Oshlun 8” set is based on, and it was excellent. I do have an Oshlun 40T blade that I think is well made and is a super value at $25, so hopefully you’ll be pleased with the dado set…you got a great price on it!
16 days ago
I’ll keep you guys posted once I’ve tried it out.
View SnowyRiver's profile
SnowyRiver
3304 posts in 372 days
16 days ago
I have an 8” Forrest set. It cuts very well…very nice dados. Its nice to have the extra 2 inches over a 6” if you are going to do any tilting of the blade for an angled dado.
-- Wayne - Plymouth MN
View nmkidd's profile
nmkidd
381 posts in 65 days
16 days ago
Charlie…...I wrote a review on the Oshlun 6” set about 3 weeks ago….....Check it out “To Dado, or Not to Dado. What a Question”
Have used the set quite a bit and it performs well.
-- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke!
16 days ago
Doug, thanks. Actually, your review was one of the things that helped make my mind up.
nmkidd
16 days ago
Glad you found it informative….......BTW my saw is the same hp as yours and to date never had a prob with this set of dadoes.
I see you already ordered….....enjoy!!
TopamaxSurvivor
2994 posts in 568 days
16 days ago
I hope you’ve been a good boy and don’t end up with a lump of coal!!
16 days ago
Topamax…buying your own gifts insures success!
View Roz's profile
Roz
453 posts in 678 days
14 days ago
Good topic, thanks! My dado is junk and leaves very ragged surfaces. I didn’t even stop to think about the poor job it was doing until I read this. Now I know what to replace it with. Once again, I have learned from you guys.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
