HELP
Forum topic by MisconductOIB posted 08-21-2015 10:55 PM 773 views 0 times favorited 6 replies Add to Favorites Watch
View MisconductOIB's profile
MisconductOIB
2 posts in 975 days
08-21-2015 10:55 PM
I have a ton of 4×6x14-16’ rough cut Doug Fir that I want to size down to work with what are my options to cutting it down in size to use. I’d like to use a band saw but not sure of size I would need since I am missing that in my shop.
View joey502's profile
joey502
525 posts in 1483 days
#1 posted 08-22-2015 01:23 AM
Are you planning to cross cut the lumber into more manageable sizes before you use the band saw? I assume your end goal is to have thinner stock to use.
What type of projects do you have in mind for this lumber?
View BurlyBob's profile
BurlyBob
5403 posts in 2231 days
#2 posted 08-22-2015 01:33 AM
If your wanting to dump some and anywhere close I’d be happy to take some off your hands.
View chrisstef's profile
chrisstef
17307 posts in 2972 days
#3 posted 08-22-2015 01:51 AM
Id resaw it to maximize the vertical grain side as much as i could.
I wrestled some 6”x6” fir timbers when i built my bench. Im still a bit achey a month later.
View AlaskaGuy's profile
AlaskaGuy
4045 posts in 2274 days
#4 posted 08-22-2015 09:27 AM
Leave as is until you have a plan. After you have a plan process just enough for your project.
Process means, cut to lengths, re-saw, joint, plane to sizes for you plan.
MisconductOIB
2 posts in 975 days
#5 posted 08-22-2015 02:39 PM
Yes I plan to cut it down to 8 foot and 10or12 lengths. After that I wanted to use some to build a nice workstation bench then from there not sure yet. Once I get it crosscut to length will a shop band saw handle ripping down the thickness?
AlaskaGuy
#6 posted 08-22-2015 05:05 PM
“Will a shop band saw handle ripping down the thickness”?
My shop band saw would re-saw that easily.
