Planer/jointer help requested
Forum topic by Medickep posted 08-21-2015 10:24 PM 726 views 0 times favorited 3 replies Add to Favorites Watch
View Medickep's profile
Medickep
569 posts in 1702 days
08-21-2015 10:24 PM
I acquired an old jointer and finally rebuilt it as well as got a planer. I know enough to be dangerous with them.
Since I’ve volunteered to make beds for a charity group, mostly out of 2x material, I thought these two tools would help shave off some of the sanding required.
I understand that both require the blade to go in the direction of the wood grain like a router but noticed especially with the planer, the wood would peel around the knots regardless of the direction I fed them.
Is it just hard to plane with this type of wood, or am I missing something?
Thanks for any help!!
-- Keith
3 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2654 days
#1 posted 08-22-2015 12:23 AM
Planers and knots do not play well together. You might try a couple of tricks: take really shallow passes and mist the surface with water before planing. I’m assuming your blades are SHARP. Pine knots are hard and will dull blades.
TheWoodenOyster
1313 posts in 1899 days
#2 posted 08-22-2015 12:59 AM
Agree with above. Knots don’t plane well not matter which way you send them thru. I have had success dampening the wood as well.
-- The Wood Is Your Oyster
Medickep
#3 posted 08-23-2015 11:30 AM
Thanks guys I appreciate the help! Glad to know it was just me!
-- Keith
