Talking about plumbing...
« back to Coffee Lounge forum
Forum topic by timthetoolman posted 1321 days ago 694 views 0 times favorited 5 replies Add to Favorites Watch
View timthetoolman's profile
timthetoolman
41 posts in 1525 days
1321 days ago
Hello, I am a woodworker, but i recently had to go to my wife’s friend’s house to fix their leaking bathtub faucet she had been complaining about the past few days, saying it was leaking. Mind you, i have only done plumbing with pipes several years ago on my tub, and could not get the shower pipe from leaking and had to call a plumber.
The past few weeks they have been keeping the knob of the faucet on by twisting it hard to turn off and keep the knob from falling. and right below the tub you can see thru the wall down below is the electric panel!
I get over there, and the thing has the knob completely sheared off and water just pouring out of the cold water pipe where the knob was. they didn’t even turn the water off the past few days. What a water bill they are going to have, and since, I told them i could fix it for $125.00 for parts. Before I went over, i looked and looked all over my garage for my plumbing supplies, the very few i had, solder, flux, torch, pipe cutter. could not find any of it.
I went to Lowe’s down the street, and chose a new faucet, $60.00 with the hose they needed to match the older one they have gotten used to. the other money was for my supplies, and one 2 foot piece of copper and some elbows and straights.
All in all, it took me 5 hours, and 12 sweat joints to reinstall the faucet. turned the water on, and no leaks!
they were very happy and i was proud of myself for learning to sweat pipes as i went. the trick is the right amount of heat with the torch with the flux, not to burn the flux off.
-- Tim The Toolman Dayton, Ohio
5 replies so far
27253 posts in 2018 days
#1 posted 1321 days ago
That was nice of you to help them out like that, Tim. And good job on the plumbing as well. If I had tried that I guarantee you I would have had to make several trips to Lowe’s and ended up doing the job twice since I always have leaks when I do plumbing jobs. :)
View mics_54's profile
mics_54
581 posts in 1667 days
#2 posted 1321 days ago
http://www.contractors-license.org/oh/Ohio.html
-- Dan, Sterling Alaska, Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
View NathanAllen's profile
NathanAllen
376 posts in 1341 days
#3 posted 1321 days ago
mics_54,
I think we can safely call that an in-kind replacement/repair. If he had been moving the piping to another location or adding a new fixture he should have pulled a permit and applied for a license/put up bond.
I’d be more concerned with the builder, general contractor and approval board who thought installing a bathroom directly above the junction box was a good idea.
But I do agree “us” homeowners get too much of a sense of “I can do it.” Not pulling permits or hiring a licensed contractor and other ignorant activities. Great example; for my garage remodel the electricians I had hired spotted an issue with the GFCI for the outdoor outlet installed by the builders. They repaired it for a small amount, problem avoided.
If I had been gung-ho about the electricity I’d have never spotted it and my inspection would likely have went poorly.
89028 posts in 1774 days
#4 posted 1321 days ago
I Hate plumbing. This was a kind act to help these folks.
mics_54
#5 posted 1321 days ago
Oh good then nobody will mind if I do surgery on the side as long as I only charge a little bit. Maybe sell pharmacuticals? I mean laws don’t really matter and I’m sure they are only established for large jobs or “special people”. I can appreciate the hypotheticals concerning the guesses as to who built the structure originally and if it was a licensed builder but I know alot of houses are built by “owners” that don’t know what they are doing. That doesnt negate the point that it is illegal under any circumstances to charge some one to repair, replace, install plumbing, fixtures or otherwise contract or advertise to do so with in the jurisdiction indicated in the OP.
I deal with the problem often. While I appreciate the need of the subject owners/renters (whichever, but opens up other issues) to get repair work done cheaply, I also know that a licensed, insured, trained and bonded contractor also needs to make a living and DESERVES that the governing authority that requires the above limitations, which by the way are very expensive to obtain and maintain, be protected from individuals that conduct illegal commerce.
If one person doesn’t have to follow the rules…nobody should. It doesn’t matter if it’s for 25 dollars or 25 thousand. To further reinforce the assertion…your electrical outlet receptical cost $2.00. Installed incorrectly it could kill you or maybe even damage your power tool.
By the way…we didn’t even address liability and the enormous risk he took helping in this manner without liability insurance. The home owner also was at risk were he injured in the process. Remeber..no good deed goes unpunished.
