| Forum topic by bruc101 | posted 17 days ago | 305 views | 0 times favorited | 11 replies | ![]() |
17 days ago |
I need some advice from some of you that have experience finishing hard maple. I’ve work very little with hard maple in all my years in the business. I have a reg customer that brought me a dining room table and 6 chairs today made out of hard maple and was made in the early 50’s. She wants the base and chairs painted with a museum quality finish and the top stained, or dyed a darker color. Sorta made me sick to hear this because it’s a beautiful dining set but she is the customer and I’ve built this lady several kitchens and she has never failed me. Thanks -- "Give The Gift of Life, Adopt A Child" |
17 days ago |
Get Charles Neils dvd “finishing a-z “it covers tons of finishing. And if you ask they might put a rush on it .It’s worht the money 10 times over. -- Jim from Heirloom Woodshop Southern Oregon |
17 days ago |
I’m currently building a curly hard maple cupboard/hutch and I’ve decided upon using water soluble Transtint Dark Vintage Maple dye. Here is a picture of my sample board: Here is a quick overview of the process I used.. from Robert L. Millards Chest on Frame Article If interested, the article goes into great detail.. FYI, my dye ratio was 30 drops to 6 oz. of distilled water. -- Scott, Colorado |
17 days ago |
Maple doesn’t stain very well without some sealers to help the stain cover more evenly. I know that the Minwax Polyshades isn’t overly well thought of, but I’ve some success with it on existing furniture piece and it might be a reasonable solution for the top. Good luck! |
17 days ago |
I use 1 good coat of oil/varnish to bring the grain out then wipe on poly, I like gloss on maple -- MARK IN BOB, So. CAL |
17 days ago |
You might go to the Wood Magazine “Finishing Forum” and pose this question to Steve Mickley (the Forum Host). He will give you excellent suggestions on what to do. -- Roger1 |
17 days ago |
I also remember a good series on thewoodwhisperer about staining maple. My technique: Move up the color scale, don’t expect maple to take dye in a single session. Keep working the color up. TT dye is remarkably flat in color when dry. Add a clear or tinted dewaxed shellac layer to bring it to final color/add depth. Be very gentle, since the dye likes to move if you’re rubbing to hard. Finish with Waterlox, lots of thin layers. Don’t rely too much on the shellac layer for coloring, just toning the warmth of the top. |
17 days ago |
Hey, just my 2 cents. I have worked with hard maple a lot. Don’t like to though. I have used transtint dyes a lot also, works well with Maple but I don’t like using transtint dyes. If you run out, then you need to try and remix more and hope you have enough transtint dye on hand or you will have to run to woodcraft or order more online. I always mixed transtint 50/50 water and denatured alcohol. I always tended to run out, and have even mixed a second batch that turned out just a shade different than the original batch. To me it was a pain. Not a cheap route either at around 19.00 for 2 ounces. I love simple does it. I have had great success with staining maple. I always will sand my maple with 120 grit and no higher than that. The grain is already tight and going higher will close the grain further, reducing the ability to get good stain penetration. Careful with your sanding technique, it really needs to be flawless, if you leave sanding marks they will jump out at you after you apply the stain. When using ROS sometimes you might get swirl sanding marks and so forth. Your sanding has to be even and perfect throughout. I then have my customer pick out a sherwood stain color of their choice. I apply the stain with spray or brush or rag, whichever is most efficient at the time. Then I personally finish it off with a lacquer process, but beyond getting an even stain color you could choose to finish with whatever method suites you fancy. I personally do not like poly because I don’t like the high gloss and I don’t like the slow dry times. However I have sprayed on poly in the past for customers desiring a high gloss look. As mentioned before, stain will only go so dark, beyond that you will have to look at dyes. If you look at my webpage at the ‘media cabinets’ under products page, you will see maple cabinets finished using transtint. Looking under ‘cabinet refacing’ you will see some maple finished with a sherwood stain. Also you can look at the ‘wall unit entertainment center’, that piece is maple and was stained expresso, but looks simply black, using transtint dyes. Have fun! -- Jerry Nettrour |
16 days ago |
Depending on how dark she wants to go, you are going to have to use an aniline dye. Also, the finish that is on the set now can also cause you headaches. Most furniture pieces are now being coated with catalytic varnishes, which is a whole other issue. Also, a real good respirator should be used with aniline dyes during mixing and application. -- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time |
16 days ago |
Thanks guys for all your repsonses. I’ve got some time on this and she brought me a coffee table made by the same company and purchased at the same time. It had been in storage for about 20 years, nothing special so we’re going to use it to practice on. She’s got some really nice hard maple furniture including a buffet and china cabinet that matches this table and can’t imagine why she wants to change the table. I asked and she made the comment, because I want it, She’s 82 years old and known me all of my life so I sho not argue with her. lol -- "Give The Gift of Life, Adopt A Child" |
16 days ago |
Have you thought about using varathane (water base) and adding the color to it. Seal the Maple and then top coat with the colored (stained) varathane. You can build up coats to get the darkness you need and then clear coat that to protect it. -- Les B, Oregon |
15 days ago |
Hay Nathan, how do you apply the waterlox? Brush or rag? Do you wipe it off to leave a thin coat. -- Mike, Westport MA. |
| Forum | Topics |
Woodworking Skill Share
2893 |
3907 |
255 |
940 |
218 |
Woodworking Trade & Swap
614 |
Coffee Lounge
2360 |
LumberJocks.com Site Feedback
522 |
