Prepping the edges of MDF before painting
Forum topic by thedudeabides posted 19 days ago 268 views 1 time favorited 7 replies Add to Favorites Watch
View thedudeabides's profile
thedudeabides
47 posts in 34 days
19 days ago
I’ve always just slopped on joint compound, sanded it smooth and then painted the edges, but I’ve heard there are multiple ways to prep the edges of MDF board before priming and painting. What do you guys normally do?
View papadan's profile (online now)
papadan
453 posts in 262 days
19 days ago
I just use a thick primer.
-- Dan-- Info for all @ http://www.hoistman.com
View Gene Howe's profile
Gene Howe
333 posts in 322 days
19 days ago
MDF can be had in different grades. The best will only require primer. Others may need the filler.
Inspect it before you bring it home. BORG stuff usually requires filler.
-- Gene
View vonhagen's profile
vonhagen
121 posts in 56 days
19 days ago
there is mdf edgeband and it works awesome, you can iron it on or use an edgebander
-- blaine von hagen
Gene Howe
18 days ago
blaine,
Never heard of that stuff. Where do you find it?
-- Gene
View CharlesNeil's profile
CharlesNeil
159 posts in 764 days
18 days ago
one of the best MDf, edge sealers is BIN by Zinnzer , it is a white primer and shellac based , i usually quick sand the edge with some 320 just to cut bown the fuzz, then apply 2 coats of the BIN, and scuff sand with some 320, the shellac based primer seals super well, for a clear i use seal coat, also shellac based, most of the box stores carry it, i know Lowes does…
vonhagen
18 days ago
euro systems, eb bradly co. louis and co. frost hardwoods.
-- blaine von hagen
vonhagen
18 days ago
you can also use birch or maple edge band as it is a closed grain wood and paints up very well.
-- blaine von hagen
