What size pulley for Delta/Milwaukee 6" jointer
Forum topic by Bob #2 posted 17 days ago 203 views 0 times favorited 12 replies Add to Favorites Watch
View Bob #2's profile (online now)
3033 posts in 913 days
17 days ago
Topic tags/keywords: jointer pulley size deltamilwaukee rebuilding
I have obtained and old Delta/Milwaukee 6” jointer.
It needs some tweaking to bring it back into service.
Right now I’m rebuilding the pulleys and belt drive which were improperly installed when I got it.
My question is:
The top pulley looks original ( 2-3/4”) diameter.
The lower (motor) pulley is also a 3”.
The motor is 1 hp/1725 rpm with a 3/4” keyed shaft.
I want to bring up the rpm to the 4000- 5000 rpm range.
What size of lower pulley would you choose for this?
I am torn between a 5-3/4 and a 6-1/4.
Both are cast iron.
View Tony's profile
Tony
812 posts in 922 days
17 days ago
Hi Bob
Try this link . I use it quite often and have found it very useful.
It looks as if you want to increase the rotational speed of the cutting head quite considerably – take care of the cutter head bearing, that they can withstand this higher speed, also watch out for induce vibration or imbalance in the head.
View doyoulikegumwood's profile (online now)
doyoulikegumwood
276 posts in 884 days
17 days ago
howdy bob i would also ask the folks over at owwm about this they seem to know just about anything you would want to know about fixing up old machines
http://www.owwm.org/
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
17 days ago
Hi Tony:
The one I have here resembles the one on the right in the pic above.
It looks like the lower motoer pulley is almost the same diameter as the motor??
I tried a 6 inch on it last night and it seemed happy. It hard to tell until you have been running it for and hour or so.
Gumwood, I will have to take you up on your suggestion as I really have no idea what should be used with the current head and bearings.
View GMman 's profile
GMman
1344 posts in 589 days
17 days ago
I have a little 4’’ that looks a lot like your picture.
I don’t have the pulley size but the top one is very small compare to the one on the motor.
I will check tomorrow the size.
-- --<<<<<< I will not stop until I get it right. >>>>>>--
16 days ago
I took Doyoulikegumwood’s advice and got on the old wood machines forum.
They had an original manual there and I found the size required to be 7” for a 1725 motor.
What a neat site!
It’s a bit rough for navigation but full of usefull info.
Thanks to all who responded to me.
View Dusty56's profile
Dusty56
3455 posts in 580 days
15 days ago
Hi Bob , I also have a Delta Milwaukee / Rockwell Delta jointer and the pulley sizes are 2 3/4” and 7” hooked up to an old HOOVER 1725rpm motor. I can’t find a model number on jointer , just a serial number on the tag.
I wish we could put pictures in this comment section without all of the photobucket , etc. issues.
15 days ago
Dusty, I swapped out the lower pulley for a cast iron V pulley 8”.
I now need to swap out the top 2-3/4 jointer pulley lor a “V” style at 3”
I should now be running around 4500 RPM according to the Link that Tony showed me above.
I figure by tomorrow I should be able to figure out the proper belt length. <g>
p.s. There is a tutorial on here that may help you get photobucket to work.
GMman
15 days ago
Sorry Bob I was going to measure the size of my pulleys and yesterday I had an accident and damaged my left hip, now I have to get use to my crutches.
15 days ago
Bummer GMman. Get well soon.
Dusty56
15 days ago
Bob 2 , Using Tony’s pulley rpm calculator tells me that mine is running at 4390.125 with my present arrangement…..if I were to reverse the pulleys , it would only run at 676.2rpm…Go figure !
I also have V-belt “technology” on my antique unit : ) I guess it also matters where the belt is actually riding in the “V” of the pulley. Thanks for making me gain some knowledge by posting your question : ) I’ll give Gary’s picture upload link a shot ….thank you and have a good weekend.
View albut's profile
albut
47 posts in 584 days
15 days ago
simple calcul: motor speed x motor pulley divide by driven pully (jointer pulley)
1725×6/2.75=3763.63 rpm
Dusty56
14 days ago
Thanks albut...I arrived at the same speed as posted earlier using both methods. 4390rpm : )
