Dont know the right terminology - but i need a supplier for this..hehe
Forum topic by depictureboy posted 19 days ago 299 views 0 times favorited 10 replies Add to Favorites Watch
View depictureboy's profile
depictureboy
306 posts in 536 days
19 days ago
I am making a shadobox display case. The back sits in a rabbet in the frame. I need to find some of those dohickeys they use on the back of pictureframes to help keep the back in place but then allow the person to open it up if they want to change some things.
I have the backpiece flush with the back of the sides, so I need something that lays flush…it would also need to use small screws as I only have 3/8ths worth of wood to work with…
Thanks for any ideas…
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View lew's profile
lew
4485 posts in 649 days
19 days ago
20629 posts in 716 days
19 days ago
It sounds like you are wanting a point driver. They are not cheap but, if you are going to do any framing at all, they are worth the money.
You can also use brad nails and needle nose pliers but the push points are easier and hold better.
16770 posts in 471 days
19 days ago
Try woodworkers Supply
View Gary's profile
Gary
579 posts in 327 days
19 days ago
Hobby/craft store has those things
-- Gary, DeKalb Texas
depictureboy
19 days ago
Lew that is exactly what I was looking for THANKS!!!!!!
Scott…those wont work for me because the back is flush together(the back may even be a little proud of the sides)
View lew's profile
lew
19 days ago
I couldn’t remember what they were called, either! But I had a whole bag of them in the shop. Bought them to hold the backs on a bunch of triangular flag cases. Hope you post the display case when it’s finished.
Lew
depictureboy
18 days ago
I will, but it will be after xmas since my mom follows my blog…hehe
View UnionLabel's profile
UnionLabel
148 posts in 94 days
18 days ago
John, try Michaels they should have a variety of sizes and will be alot cheaper than a woodworkers supply store.
They have an entire picture frame department. I have even bought frame material from mine to make my own frames.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
depictureboy
18 days ago
Michaels was the first place I looked. The lady in the Framing department had no idea what I was talking about, and when I showed her she promptly told me they do not carry those type of items…<sigh>
View Kent Shepherd's profile
Kent Shepherd
813 posts in 180 days
18 days ago
Doesn’t it amaze you that woodworkers always seem to know what a dohickey is, whatever your personal application?
