DeWalt 788 Air nozzle
« back to Scrollsawing forum
Forum topic by lakebound posted 08-20-2015 10:21 PM 951 views 0 times favorited 6 replies Add to Favorites Watch
View lakebound's profile
lakebound
14 posts in 2937 days
08-20-2015 10:21 PM
The air nozzle on my DeWalt 788 was accidentally pulled apart. Any suggestions on how to reconnect the joints. Thanks for all suggestions.
Lakebound
View distrbd's profile
distrbd
2252 posts in 2352 days
#1 posted 08-20-2015 11:34 PM
The airline or the nozzle usually do not come apart unless there’s a hairline crack on the piece that came loose, I would examine the part carefully to make sure it’s not cracked.
-- Ken from Ontario, Canada
View David Taylor's profile
David Taylor
326 posts in 993 days
#2 posted 08-21-2015 02:58 AM
Mine did that same thing. I ended up buying a new one from Dewalt. http://servicenet.dewalt.com/Parts/Detail/19003
-- Learn Relentlessly
View tomsteve's profile
tomsteve
753 posts in 1125 days
#3 posted 08-21-2015 11:27 AM
If its not cracked, put a hairdryer on one end for a bit( end that slides onto works for me) and let it soften up a bit.
View Redoak49's profile
Redoak49
3076 posts in 1894 days
#4 posted 08-21-2015 01:44 PM
I think the air nozzles on most scroll saws are a pain. I replaced the hose and nozzle with a Loc-Line 1/4” assembly kit which was about $10. It has worked great for me and makes it much easier to position the nozzle.
View CharleyL's profile
CharleyL
222 posts in 3270 days
#5 posted 08-22-2015 02:32 PM
If the end that attaches to the saw is broken, just slowly and carefully pull it off and discard it. Then push the remaining links onto the saw. A little warming helps. I dip them in boiling water for about 30 seconds and then push them onto the saw or together. The heat makes them more elastic and less likely to break. I had the first air nozzle assembly break and ordered a replacement. I repaired the original by removing the broken link. When the new assembly arrived I put both together and made the line longer, but didn’t use the full length. The spare nozzle tip and about half of the replacement line are in my saw parts box waiting for the next time that I break one or more of the links on the saw. All the links are the same except for the nozzle tip.
Charley
lakebound
#6 posted 08-23-2015 10:43 PM
Thanks for all the suggestions. Used tomsteve’s suggestion of using a hair dryer. Worked great. Thanks again.
