Router table miter track source
Forum topic by jcsom posted 23 days ago 194 views 0 times favorited 5 replies Add to Favorites Watch
View jcsom's profile
jcsom
2 posts in 23 days
23 days ago
Does anyone know of a source for a steel miter track/slot?
I have a homemade router station with a combination T-track/miter track, but it’s aluminum. The problem is the miter bar on my coping sled is also aluminum, and when it slides through the aluminum track the bar and slot both eventually develop little burrs and the sled no longer slides smoothly. I’d like to replace the aluminum track with a steel one, but have had no luck finding such a thing. Anyone?
16993 posts in 474 days
23 days ago
I would check out Rockler and MLCS and Woodworkers supply.
View cstrang's profile
cstrang
1220 posts in 65 days
23 days ago
You could also try Lee Valley
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
20735 posts in 719 days
23 days ago
What about replacing your aluminum miter bar with one made from steel? Ttrackusa sells steel miter bars in addition to aluminum t-tracks.
View Bill White's profile
Bill White
111 posts in 858 days
22 days ago
Aluminum track and steel bar for the gauge. No probs. Alum to alum will get some galling.
Bill
jcsom
2 posts in 23 days
22 days ago
Thanks for the suggestions. Unfortunately, no luck at Rockler, MLCS, WWS, or Lee Valley. Anywhere else I might try?
As for a steel bar in the aluminum track, I’ve actually tried that, but have had similarly poor results. It seems like the aluminum track is just too soft to maintain it’s interior width for a decent amount of use. Then I end up with too much slop between the steel bar and the track to be acceptable. I’d really like to have a steel bar and steel track.
