Which Saw Blade
Forum topic by Notw posted 08-20-2015 08:41 PM 1246 views 0 times favorited 11 replies Add to Favorites Watch
View Notw's profile
Notw
672 posts in 1958 days
08-20-2015 08:41 PM
I am trying to decide between the following three saw blades:
-Freud D1050X
http://smile.amazon.com/D1050X-Diablo-50-tooth-Combination-PermaShield/dp/B00008WQ2Z/ref=sr_1_1?ie=UTF8&qid=1440101169&sr=8-1&keywords=diablo+1050
-CMT P10050
http://smile.amazon.com/CMT-P10050-Combination-Blade-8-Inch/dp/B00BIE0SHW/ref=sr_1_1?ie=UTF8&qid=1440101205&sr=8-1&keywords=cmt+p10050
Irwin Marples 1807368
http://smile.amazon.com/Irwin-Tools-1807368-50-Tooth-Alternate/dp/B008OJJXZC/ref=sr_1_1?ie=UTF8&qid=1440101344&sr=8-1&keywords=irwin+marples+10
I don’t like to change blades when switching cuts so i am looking for a good general purpose blade, all of these are around the same price and all have 5 stars on amazon. Thanks
11 replies so far
View bigblockyeti's profile
bigblockyeti
5290 posts in 1926 days
#1 posted 08-20-2015 08:56 PM
I’d go with the Freud, never had a problem with any blade from them and the coating does seem to make them a little easier to clean pitch from.
View WhyMe's profile
WhyMe
1075 posts in 1766 days
#2 posted 08-20-2015 10:10 PM
All 3 are good. Pick which color you like best. They all may come from same factory in Italy.
View johnstoneb's profile
johnstoneb
3063 posts in 2378 days
#3 posted 08-20-2015 10:24 PM
I have the Irwin Marples and it leaves a glue surface edge. As Why me says pick a color you can’t go wrong.
-- Bruce, Boise, ID
View knotscott's profile
knotscott
8154 posts in 3581 days
#4 posted 08-21-2015 01:34 AM
The P10050 has teeny tiny little chips of carbide. I’d give the Irwin Marples a shot.
There’s a good comparison review between the Marples and D1050x from Lumberjoe
View Billy E's profile
Billy E
162 posts in 2285 days
#5 posted 08-21-2015 01:37 AM
I’ve tried 50 tooth blades before and I don’t think they are as good as a 40 tooth blade at either ripping or crosscuts. They usually leave a near flat bottom groove due to the raker, if that matters to you.
-- Billy, Florence SC
View TheFridge's profile
TheFridge
10763 posts in 1691 days
#6 posted 08-21-2015 01:44 AM
I’d say buy any one of them. Then save up and buy a Forrest ww2 or one of the many other top shelf blades.
View ForestGrl's profile
ForestGrl
450 posts in 1291 days
#7 posted 08-21-2015 02:32 AM
Ditto to what Billy said, if you’re not wanting to switch blades for different cuts.
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
View tacocat22's profile
tacocat22
9 posts in 1215 days
#8 posted 08-21-2015 06:33 AM
Woodworking techniques are of course a personal preference. My preference even though it can be a pain to change them often is to have dedicated blades. I have a 80 tooth freud for plywood, a 40 tooth forrest ww2, and a freud rip blade that I absolutely love. The rip blade just ate through the 8/4 maple I threw at it. I have never used a 50 tooth blade but I like freud a lot so I would recommend a 40 tooth freud.
View Notw's profile
Notw
#9 posted 08-21-2015 02:29 PM
The P10050 has teeny tiny little chips of carbide. I d give the Irwin Marples a shot.
There s a good comparison review between the Marples and D1050x from Lumberjoe
- knotscott
So i was all set to get the Frued because i’ve used them in the past and liked them but now i’m leaning toward the Irwin after reading this review. Just got to decide between 40 or 50 tooth
knotscott
#10 posted 08-21-2015 04:11 PM
So i was all set to get the Frued because i ve used them in the past and liked them but now i m leaning toward the Irwin after reading this review. Just got to decide between 40 or 50 tooth
- Notw
I’ve done quite a bit of cutting and testing on several 40T and 50T blades. Most of those 40T blades were top shelf models like the Super General, WWII, Gold Medal, TS2000, Freud Premier, CMT, etc., but have also given the Freud LU86 and very similar Diablo D1040 40T, as well as the LU84 50T and similar D1050x a good run. All of the previously mentioned top shelf premium blades have very tight side clearances to give the cut a high degree of polish. All of those blades will also leave a slightly shinier edge than any of the 50T ABT/R or less expensive 40T blades I’ve used. The D1040x or the Marples equivalent don’t feature the tight side clearances that the premium 40T blades offer, meaning there’s not a ton of notable difference between the 40T and 50T blades at this price point. Either should be fine, so if you had your heart set on a 50T, don’t sweat the difference. They’re all really good performance at great prices. The upside to not having the tight side clearances is less tendency to burn, and less fussiness in general about the setup.
Joe’s review is very good and quite compelling for the Marples. Keep in mind that most blade comparisons involve a sample size of 1 of each type, which means variability likely becomes part of the equation….not every blade is perfectly representative of the whole population, but it’s usually just not feasible to try multiples of same models to rule out that variability.
View dschlic1's profile
dschlic1
442 posts in 2175 days
#11 posted 08-21-2015 04:47 PM
I am using a Diablo DX1080. Top notch crosscuts with no tear out and I can rip 3/4” stock with no issues. I do have a 24 tooth rip blade but rarely use it.
