Turquoise Inlay
Forum topic by Rusticman posted 18 days ago 288 views 1 time favorited 6 replies Add to Favorites Watch
View Rusticman's profile
Rusticman
41 posts in 295 days
18 days ago
Topic tags/keywords: inlay turquoise epoxy walnut checks cracks finishing sanding rustic modern tip question trick
I have several large Walnut slabs that are just screaming “Turquoise Inlay” but I have no information on how to proceed with this technique. From what I have learned so far a two part epoxy with some turquoise chips inserted in the top of the epoxy and sanding it smooth is all it takes. Is it all really that easy?? Any recommendations or procedures any one would like to share?
-- Dave, Ohio,www.rusticforest.com
7599 posts in 1110 days
18 days ago
Check out Candy Hicks project page. She uses turquoise inlay a lot, and I’m sure if you sent her a message she would be glad to offer some suggestions.
I’ve done a few stone/epoxy inlays, and it is pretty much a straightforward procedure just as you described.
View vonhagen's profile
vonhagen
121 posts in 54 days
18 days ago
go to a rock shop and get some epoxy 3 or opticon , as these are the best for being transparent and have the best holding power in stone, opticon is acctualy for fixing fractures in gemstones, another thing you can do is use molten silver and then grind off and polish. i have poured silver into checks and knots with amazing results
-- blaine von hagen
View socalwood's profile
socalwood
968 posts in 496 days
18 days ago
On stone – Candy Hicks. I use atomized metals and epoxy frequently with good results on specimen pieces . Look for my next projects post.
-- rob
View Autumn's profile
Autumn
77 posts in 44 days
18 days ago
I did a nice tourquoise inlay once when the wood kept yelling at me, saying that’s what it wanted. I wrapped some turquoise in a towel and smashed it with a hammer. I filled the holes with the crushed rock, then I used System Three long-set epoxy (dyed black with System Three Epoxy dye). I taped off the area as if I were taping for a paint job, then poured the epoxy over the rock. Over the next hour or so the epoxy seeped down into every nook and cranny and I added a little more. The next day I hit it with a grinder of successively finer grits. It was stunning.
View eastside's profile
eastside
48 posts in 153 days
15 days ago
Were do you get the tourquoise in the first place?
-- Mike, Westport MA.
View reggiek's profile
reggiek
704 posts in 162 days
15 days ago
Most craft stores carry turquois for inlay (www.woodturnerscatalog.com, www.arizonasilhouette.com (you can do a search online for it also)...either as powder or crushed stone….some also have bigger pieces, other places would be a mineral store…or a jewelry supply….I’ve seen some on Ebay too,
