Painted desk build. Which plywood?
Forum topic by CudaDude posted 08-19-2015 05:28 PM 1285 views 0 times favorited 10 replies Add to Favorites Watch
View CudaDude's profile
CudaDude
179 posts in 2216 days
08-19-2015 05:28 PM
What type of plywood should I use for this desk? http://lumberjocks.com/topics/111386
Obviously I want something that’s going give a nice painted finish. After visiting a couple local building suppliers and the big box stores, I’ve got nothing. I’m thinking birch plywood, as it’s always talked about like it is quality plywood, but when I looked at the birch that one of the building suppliers had, it was horrible… Veneers peeling and a lot of voids in the edges (it was still $25 for a 2×4 sheet). Are there different grades of birch? They did have some 3/4 maple that looked good, but I wasn’t sure how it would accept a painted finish. Thanks in advance
-- Gary
10 replies so far
View HokieKen's profile
HokieKen
4625 posts in 1047 days
#1 posted 08-19-2015 05:45 PM
I’ve painted birch ply from big-box stores with success on cornhole boards. It takes paint very well. I cover the edges with a thin coat of drywall mud and fill any voids in the face with wood filler. Then sand the whole thing with 320. Prime, sand with 400 then a second coat of primer. Hit the second coat of primer with 600 just enough to smooth it all out. If necessary you can keep priming/sanding until your happy with the surface consistency but I’ve never needed more than 2 coats. After that you should be able to get a nice uniform finish with your paint of choice. That being said, I don’t see why this method wouldn’t work with any plywood. I just use birch because I have better luck finding flat pieces than I do with maple or oak ply. For a desktop, I’d finish it off with a couple of coats of poly for protection.
Oh yeah… beware tear-out when your cutting it. If you do have splintered edges, fill & sand them until you can’t feel them or they’ll stick out like a sore thumb when it’s painted.
-- Kenny, SW VA, Go Hokies!!!
View paxorion's profile
paxorion
1107 posts in 1954 days
#2 posted 08-20-2015 03:58 AM
I used Columbia Forest Products PureBond birch plywood (from Home Depot) for my last painted wall cabinets project. It took a few steps but took paint very well. Edge banding will work better than drywall mud for the edges. I used a combination of thin veneer (works) as well as hardwood edging (I used poplar and it took a few steps, but works very well).
-- paxorion
View pjones46's profile
pjones46
1000 posts in 2551 days
#3 posted 08-20-2015 04:17 AM
You can also look at double sided MDO and band the exposed edges or do as HokieKen suggested cover the edges with a thin coat of drywall mud.
-- Respectfully, Paul
View MT_Stringer's profile
MT_Stringer
3154 posts in 3139 days
#4 posted 08-20-2015 04:51 AM
Plywood is graded with A1 being the best (good both sides, no patches).
I have used birch from HD before just like paxorion did.
http://www.homedepot.com/p/Columbia-Forest-Products-PureBond-Birch-Plywood-FSC-Certified-Common-3-4-in-x-4-ft-x-8-ft-Actual-0-703-in-x-48-in-x-96-in-332941/202887466
Looks like it is grade C3
The home owner sprayed them.
4885 posts in 2401 days
#5 posted 08-20-2015 12:08 PM
All the above suggestions are good, and the maple you saw will take paint very well. I would probably try to get the Columbia Purebond as my experience with it has been very good…but any of the mentioned products should serve you well.
17572 posts in 1765 days
#6 posted 08-20-2015 12:27 PM
For anything painted I use MDO plywood and poplar face frames. The MDO does not have any raising of grain like any wood faced plywood will have.
CudaDude
#7 posted 08-20-2015 05:30 PM
Thanks for the responses and suggestions. Is MDO heavy like MDF?
-- Gary
View MrRon's profile
MrRon
4634 posts in 3152 days
#8 posted 08-20-2015 05:35 PM
I second the use of MDO. It is more expensive, but it was intended for painting. Highway signs are made from using MDO. If you use a big box store, get a plywood with a maple or pine surface.
#9 posted 08-20-2015 05:58 PM
MDO is about the same weight as any other 3/4” plywood. It has a veneer layer of fiberboard on each side, but the inner layers are the same as hardwood plywood. I buy MDO at menards for $65 and sometimes on sale for less. You can also get it in 1/2”.
View Billy E's profile
Billy E
162 posts in 1988 days
#10 posted 08-21-2015 01:43 AM
I’d just use whatever is cheapest and fill voids with wood filler or drywall mud. You can pay a lot of money for high end plywood. I wouldn’t do it just to paint over it.
-- Billy, Florence SC
