Table saw motor - how to mount
Forum topic by Keegs22 posted 08-18-2015 10:00 PM 1733 views 0 times favorited 7 replies Add to Favorites Watch
View Keegs22's profile
Keegs22
2 posts in 916 days
08-18-2015 10:00 PM
I bought this Grizzly TSC-10 table saw used. I haven’t been able to find info on how to mount the motor and haven’t been able to figure it out. I’m confused on how that bracket attaches to the motor and wondering if there could be a piece missing?
Thank you
7 replies so far
View Kazooman's profile
Kazooman
932 posts in 1856 days
#1 posted 08-18-2015 10:08 PM
First post – first response.
I Googled Grizzly TSC-10 manual and got a link to the entire document.
Is your saw different than the ones described in that manual?
Keegs22
2 posts in 916 days
#2 posted 08-19-2015 12:00 AM
Thanks for the response. It is different than the ones in that manual.
View MrUnix's profile
MrUnix
6336 posts in 2103 days
#3 posted 08-19-2015 12:02 AM
How do you get it to hang from the ceiling like that?
View knotscott's profile
knotscott
7872 posts in 3280 days
#4 posted 08-19-2015 12:15 AM
It’s likely an older Taiwanese saw made in the Mao Shan plant. It was offered in many configurations under many different brands….Jet, Grizzly, PM, Ohio Forge, Omega, AFF, Bridgewood, Woodtek, Allied, Mao Shan and many others. The motor mount system should be pretty much the same, regardless of the leg stand, fence, or wing configuration.
The contraption mounted to the top of the motor doesn’t look like it belongs there….someone added that.
View 01ntrain's profile
01ntrain
237 posts in 974 days
#5 posted 08-19-2015 02:48 AM
That contraption on top of the motor looks like some sort of tensioner…..
View JoshNZ's profile
JoshNZ
99 posts in 973 days
#6 posted 08-19-2015 03:28 AM
Surely the tension would come from sliding the whole bracket further out on those studs then doing up the grub screws… Does it hold sturdy enough if you remove the black piece (+ 2 bolts). Doesn’t look like it belongs there
View JoeinGa's profile
JoeinGa
7733 posts in 1911 days
#7 posted 08-19-2015 01:34 PM
I agree. That black piece looks like someone tried to make a plate to push down on the motor, creating more tension.
Oh and that belt looks like it has turned backwards. Those “nubs” are usually on the inside
