Gluing Felt to a Poly Finish
Forum topic by TheLastDeadMouse posted 08-18-2015 11:53 AM 632 views 0 times favorited 4 replies Add to Favorites Watch
View TheLastDeadMouse's profile
38 posts in 1310 days
08-18-2015 11:53 AM
I’m making a bocce ball carrier for my brother who’ll be my best man this Saturday. The box is curly maple, padauk and wenge and is finished with Arm-R-Seal inside and out, and I plan on putting on a coat of paste wax as well. I cut out 3/4” felt circles that I want to glue to the inside of the box where the ball would touch the sides, but am unsure of what kind of adhesive I should use that will attach to the poly finish but also not bleed through the felt and cause discoloration. Any suggestions?
View kepy's profile
293 posts in 2207 days
#1 posted 08-18-2015 01:21 PM
Aleene’s Tacky Glue comes in white or clear and both dry clear. E6000 also dries clear and is stronger.
-- Kepy
View lew's profile
11987 posts in 3689 days
#2 posted 08-18-2015 01:38 PM
Have you considered “flocking”?
View Kazooman's profile
971 posts in 1886 days
#3 posted 08-18-2015 02:11 PM
You can get felt with a peel and stick backing at a craft store. It should hold on poly just fine. If you really want to use what you have you could attach it with double sided carpet tape. The stuff I have really holds. It is designed to hold fabric to finished surfaces, just like you want to do.
View gfadvm's profile
14940 posts in 2624 days
#4 posted 08-19-2015 12:09 AM
Contact cement will work.
