Looking for band saw..
Forum topic by Etkini posted 08-17-2015 10:59 PM 634 views 0 times favorited 5 replies Add to Favorites Watch
View Etkini's profile
Etkini
3 posts in 920 days
08-17-2015 10:59 PM
Topic tags/keywords: question bandsaw
I’ve been browsing these forums for quite some time and used information I’ve gathered to start building my workshop since purchasing a house two months ago. I had access to a really nice wood shop when I was younger, then fell out of it for a while until purchasing this house and remembering how much cheaper it is to build instead of buy.
With that said, I’m looking for a band saw to add to my collection. My budget is about $600. I don’t really see re-sawing as something I would do a lot of, but things change and I’ve never complained about having too much power. I was looking at the Grizzly G0555LANV because of it’s good reviews and it being only $545 delivered, but then decided to check Cragislist, which brings me to the point of my post:
Does anyone have any info on the Grizzly G4186z? It was manufactured in 2000, is about two hours away from my house, and the guy only wants $250 which seems like a screaming deal for a 18” band saw. It looks like it’s in good shape, and comes with extra blades. I can not find any info online about it minus the spec sheet on Grizzly’s website. One thing that I did see that somewhat turns me off is it has steel block guides. I’ve always used and had saws with bearing guides, as I’ve always been under the impression metal-on-metal contract isn’t the best in moving parts, but it wouldn’t be the first time I’ve been wrong.
Thanks for any help in advance.
5 replies so far
MrUnix
6354 posts in 2105 days
#1 posted 08-17-2015 11:06 PM
One thing that I did see that somewhat turns me off is it has steel block guides. I ve always used and had saws with bearing guides, as I ve always been under the impression metal-on-metal contract isn t the best in moving parts, but it wouldn t be the first time I ve been wrong.
I prefer original HSS blocks instead of bearings or other alternatives. Metal on metal contact is not an issue, nor is the ‘heat’ myth. Take a look at this guide comparison by Jim Mattson over at the Woodworkers Gazette, where he uses and abuses the various aftermarket guides as well as the stock HSS ones:
http://www.woodworking.org/WC/GArchive99/2_24matband.html
Note his conclusion (over on page two of that article): ”If there are any advantages to the bearings, I couldn’t see them unless the bearings are quieter. I really didn’t notice.
View rwe2156's profile
rwe2156
2803 posts in 1387 days
#2 posted 08-18-2015 02:31 PM
Brad can comment, but FWIW the older model 14” Deltas or Rockwells are pretty much a bomb proof saw, aren’t they?
Unless you’re set on a new one might be worth looking for. Just a thought.
Etkini
3 posts in 920 days
#3 posted 08-18-2015 02:58 PM
Brad can comment, but FWIW the older model 14” Deltas or Rockwells are pretty much a bomb proof saw, aren t they?
Unless you re set on a new one might be worth looking for. Just a thought.
- rwe2156
Used in my area is fairly hard to come by. Used, for a good price for a saw that’s actually worth it is next to impossible. Right now my local (within 45 minutes) used market consists of a Grizzly G0514 for about $100 more than the price of a new one when you could get them. Between an 1 hour and 1.5 hours out, there’s a ton of older Craftsman 12” saws for between $100-350.
I’ve been looking at every used place I can think of, even going as low as the Facebook garage sale sites, and can’t come up with much except that G4186z but can’t find any info on it, and my mind is telling me if the offer seems too good to be true it is. And $250 for an 18” band saw just seems way too good, and without anyone having any experience with them I can’t justify driving two hours to go look at it.
View FancyShoes's profile
FancyShoes
550 posts in 1270 days
#4 posted 08-18-2015 03:00 PM
Where are you located? Many people here will have or know of good deals.
Etkini
3 posts in 920 days
#5 posted 08-18-2015 03:02 PM
- FancyShoes
Lake George area, NY. It probably would have helped it I had posted that in the first place.
