Table Saw Sled Base (MDF?)
Forum topic by fivecodys posted 08-17-2015 08:52 PM 1243 views 1 time favorited 10 replies Add to Favorites Watch
View fivecodys's profile (online now)
fivecodys
1265 posts in 1870 days
08-17-2015 08:52 PM
Topic tags/keywords: jig
Ok, so my old sled warped (thanks for all the replies on that thread) and I am in the planning stage for my next one.
My last sled had a 1/2” plywood (not birch) base and poplar fences.
What is the feeling of this group on using MDF as the base with hard wood fences?
It seems that the MDF might be less likely to warp.
Your thoughts?
Thanks in advance.
-- I always knew I would grow old, But I expected it to take longer!
10 replies so far
View rhybeka's profile
rhybeka
4420 posts in 3355 days
#1 posted 08-17-2015 09:02 PM
Hmmm – I”m interested in this on myself. I’ve seen several versions of sleds made with MDF as a base. Let me see if I can pull any of them up and link them.
-- Beka/Becky - aspiring jill of all trades, still learning to not read the directions.
19570 posts in 2090 days
#2 posted 08-17-2015 09:11 PM
My last sled was made with mdf. It lasted for many years. The only reason I made a new one was to make it bigger with a better guide. It should work just fine for you. My new one is MDO with a hardwood fence.
View WhyMe's profile
WhyMe
1080 posts in 1794 days
#3 posted 08-17-2015 09:34 PM
fivecodys
#4 posted 08-17-2015 09:41 PM
Been discussed…
http://lumberjocks.com/topics/110658
- WhyMe
Thank you. That was a good read.
WhyMe
#5 posted 08-17-2015 09:58 PM
So what’s your conclusion?
View Pezking7p's profile
Pezking7p
3230 posts in 1885 days
#6 posted 08-17-2015 10:27 PM
Didn’t read all of the other thread but I will say my 1/2” mdf crosscut sled lasted about a year and wasn’t very good at holding up to daily use. The kerf wore out and made it difficult to know where to measure to, and the screws holding my fence down started to wiggle. I just remade it with plywood base and plywood fences. I used a double thick fence on the “user side” based on my past experience.
-- -Dan
fivecodys
#7 posted 08-17-2015 10:31 PM
So what s your conclusion?
- WhyMe
Well…It seems to me that both options are viable. I used cheap 1/2” plywood last time and we know how that ended up. I’m leaning towards a better grade of plywood and maybe even making the fences out of a couple pieces of plywood glued up to see if that is more stable than solid wood.
fivecodys
#8 posted 08-17-2015 10:46 PM
By the way,
Thank you all for your speedy responses.
This is a great resource when you need a little advice from people who understand where you are coming from.
View JeffP's profile
JeffP
573 posts in 1625 days
#9 posted 08-17-2015 11:20 PM
Maybe the issue is less about “which wood” and more about using different wood for base and fence?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View rwe2156's profile
rwe2156
3225 posts in 1714 days
#10 posted 08-18-2015 02:25 PM
Well…It seems to me that both options are viable. I used cheap 1/2” plywood last time and we know how that ended up. I m leaning towards a better grade of plywood and maybe even making the fences out of a couple pieces of plywood glued up to see if that is more stable than solid wood.
- fivecodys
I think you’ve zeroed in on it.
Pros: MDF is flat.
Con’s: its heavy.
My sled is made of 3/4 MDF. Coated with shellac. Its very stable but very heavy.
Next one will be made of 1/2 Birch ply.
