Cement Floor Solution?
Forum topic by dennis mitchell posted 11-02-2009 11:39 PM 2448 views 1 time favorited 34 replies Add to Favorites Watch
dennis mitchell
3994 posts in 4365 days
11-02-2009 11:39 PM
Topic tags/keywords: question
I’ve got this hard cement floor that just kills my back. I do use lots of anti fatigue mats, but they just don’t quite do the whole job. It makes a 8 hour day impossible for me to do. Out in the field I do OK. So I want to try gluing down 4X8’s of OSB to just add that extra cushion. Am I missing any thing in my thinking? ( You have to understand my brain has been under the influence of particle board dust and lacquer fumes for many years now!)
34 replies so far
18615 posts in 4211 days
#1 posted 11-02-2009 11:48 PM
at the last wood show I was at I tried these out (Happy Feet)—oh yah.. nice!
View Chris 's profile
Chris
1879 posts in 4042 days
#2 posted 11-03-2009 12:02 AM
Dennis,
I would use these at each of my major work areas. I started using these when I started turning… Boy did they make a difference. I’m sure something like this would work well.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
dennis mitchell
#3 posted 11-03-2009 12:10 AM
Yep got the insoles and the mats. I do have degenerative disks and a slipped vertebra so I use the drugs too.
View WayneC's profile
WayneC
13754 posts in 4148 days
#4 posted 11-03-2009 12:11 AM
I’m using the woodcraft ones as well.
View John Ormsby's profile
John Ormsby
1288 posts in 3787 days
#5 posted 11-03-2009 12:13 AM
You also might look at installing a floating wood floor with foam backing or pad. Lumber Liquidator always has very good prices on excess flooring. Your shop will also be easier to clean. You can sand the floor finish after installing to make it much less slippery.
I intentionally made my shop floor with heavy duty joists and thick OSB. It is comfortable to work on.
-- Oldworld, Fair Oaks, Ca
View pommy's profile
pommy
1697 posts in 3742 days
#6 posted 11-03-2009 12:15 AM
Dennis stick with the drugs mate but seriously i wear my CROCS they are byfar the most comfortable shoe out there just wish they did a steel toe-cap version and lost the holes so the wood-dust wouldn’t get between your toes …...
-- cut it saw it scrap it SKPE: ANDREW.CARTER69
117159 posts in 3628 days
#7 posted 11-03-2009 12:29 AM
I use mats similar to the woodcraft type but kind of firm rubber with holes in it. They’re a lot less expensive then the woodcraft type
View SnowyRiver's profile
SnowyRiver
51457 posts in 3531 days
#8 posted 11-03-2009 12:30 AM
I think I would try Johs’s idea…maybe a floating wood floor, or if you have the headroom, put down sleepers and then put the boards or plywood on them. This would give you some space for insulation too.
-- Wayne - Plymouth MN
View cstrang's profile
cstrang
1832 posts in 3219 days
#9 posted 11-03-2009 12:44 AM
Have you tried the Ironworker style of steel toe boots? They have a soft sole for the guys working on the high steel, I found they helped me alot the only issue is that they wear out faster than other steel toe boots because of the soft sole, it is sort of a catch 22.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
View gbvinc's profile
gbvinc
628 posts in 3997 days
#10 posted 11-03-2009 01:03 AM
Dennis, I use mats from HF over the entire shop floor. Cheap, just soft enough, and works well for me. (Mobile equipment rolls over them ok too.) I suspect if you add flooring on top of the cushions, you would have a pretty forgiving floor. Other than that, jump into the nearest time machine, go back 20 years, and don’t do any of the things I did to mess up my back. :-)
View ChunkyC's profile
ChunkyC
856 posts in 3305 days
#11 posted 11-03-2009 01:15 AM
I like you suffer the consequences of a misspent youth and now can’t make it through the day without lower back issues. I use Horse Mats in the garage and they are awesome. Their just old recycled tires that have been ground up and glued together. Extremely durable and they vacuum up ok with a shop vac / DC, sweeping is almost impossible. It doesn’t sound that great but they are a lot better than they sound. Look for them at the local farm / tractor / hardware store like Farm and Fleet, TSC, etc. If memory serves, I think they are around $40.00 for a 4×6 mat. Take a buddy to help load and unload, they are a handful by yourself, doable, but a real handful.
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View Russel's profile
Russel
2199 posts in 3990 days
#12 posted 11-03-2009 01:22 AM
Dennis, for my garage I made a grid of 2×4 laid on the flats and then put OSB on that. It made a world of difference for me. I don’t have a back injury, but the anti-fatigue mats have never worked for me.
Dick, & Barb Cain
8693 posts in 4350 days
#13 posted 11-03-2009 01:33 AM
I’m planning on putting down some osb sturdyfloor on my garage shop floor, but I plan on laying
down some hi-density foam beneath it. I think it will also be easier to heat.
View KayBee's profile
KayBee
1083 posts in 3297 days
#14 posted 11-03-2009 01:34 AM
Try some really good boots, like redwings or timberland pro series. These boots are made for standing around on concrete. Floor mats have never worked for me, but good boots do. I broke my lower back in two places and have spent a lot of time looking for relief.
-- Karen - a little bit of stupid goes a long way
35128 posts in 4451 days
#15 posted 11-03-2009 01:46 AM
Dennis I put down about 500 Sq FT of horse stall mats. They are used in the bottom of horse stalls Mine are solid rubber and 3/4” thick. But they still don’t do the best job. It’s almost impossable to roll tools around on the rubber mats. I put down 3 sheets of OSB board, Under the table saw, planer and jointer. The OSB actually feels better to me than the rubber and the tools move effortlessly.
Good luck of getting it fixed.
If I’d had known I probably would have used all OSB board. with maybe a few rubber mats where I would stand.
showing 1 through 15 of 34 replies
