CORNER BOOKSHELF HELP
Forum topic by mikeyp posted 08-17-2015 05:50 PM 803 views 0 times favorited 10 replies Add to Favorites Watch
View mikeyp's profile
mikeyp
11 posts in 1015 days
08-17-2015 05:50 PM
I’m hoping to get some ideas for you guys. I’m building a corner cubbie shelf for my mudroom. My big million dollar question is how to do trim since it will be on an angle. I want it to be built in so the floor molding will be removed.
I feel like it might look weird with trim on the front sides that are against the walls on an angle.
10 replies so far
View Dark_Lightning's profile
Dark_Lightning
3161 posts in 3108 days
#1 posted 08-17-2015 08:58 PM
Can you provide a simple sketch? It’s tough to visualize what you are after.
-- Random Orbital Nailer
View pintodeluxe's profile
pintodeluxe
5660 posts in 2813 days
#2 posted 08-17-2015 09:04 PM
If you replace the baseboard trim, and run it continuously past the built in, it should look nice. Cut the molding at 22.5 degrees.
View JoeinGa's profile
JoeinGa
7736 posts in 2006 days
#3 posted 08-17-2015 09:07 PM
I’ve always thought these two types of shelves would be nice for any corner. You could size either to suit your needs.
mikeyp
#4 posted 08-18-2015 01:40 PM
Thanks for the responses. Joe, the pictures didn’t come through on my side.
I think I was overthinking it. So here is my plan…let me know if this makes sense.
Imagine a corner and basically making a triangle shaped cubbie. I want to have a piece of trim around the edges of the plywood (I’ll be using leftover pine from another project so I want to come the ends). Those trim pieces that would be on the two sides top to bottom is what I was trying to get to look right.
PIctures I had seen online showed shelves that had gone to the wall but the trim was on the angle as well and not flush to the wall.
But I think I need to make the “sides” of the cubbie flush with the wall and makes the shelves triangle. That way I can keep the trim flush to the wall as well.
Does that makes sense?
View Yonak's profile
Yonak
986 posts in 1520 days
#5 posted 08-18-2015 08:43 PM
- mikeyp
Sorry, for me it doesn’t. You talk about a triangle. I get that. Then you talk about plywood. Where does the plywood come in ? You talk about, “two sides, top to bottom”. Top to bottom of what ?
Can you show a sketch of what you’re describing so I can follow along ?
View bondogaposis's profile
bondogaposis
4727 posts in 2351 days
#6 posted 08-18-2015 09:05 PM
Sorry, I have no idea what you are talking about. A picture would help immensely.
-- Bondo Gaposis
View Daruc's profile
Daruc
460 posts in 1132 days
#7 posted 08-18-2015 09:29 PM
Sounds like your talking about putting molding down the 2 sides where the frame meets the wall?
If that’s the case you can 45 degree the edge of your molding so that it goes flush against the wall,
I prefer to not use molding and fit the cabinet to the walls. This is done by leaving scribe room on your frame and cutting the frame to fit the walls.
Another idea would be to come out 4 or 5 inches at a 90 degree off the wall, then start your angle,
For example:
JoeinGa
#8 posted 08-18-2015 09:49 PM
Well dang. Lets try that again
Yonak
#9 posted 08-19-2015 02:13 AM
- JoeinGa
Ah .. now I understand perfectly . . .
mikeyp
#10 posted 08-19-2015 11:24 AM
woodust has the gist of it!
Joe, I like your 2nd idea but the room zig zags a bit and I am making several units for the room.
I also don’t know why I said bookshelf. These are going to be shoe cubbies.
In this particular corner with me a triangle shelf on the floor (2 shelves and the top)...then a space for coat rack and kids back packs….then an upper shelf which will resemble what JoeinGA has on his 2nd drawings.
Thanks guys. Woodust, what program did you use for that?
